Hallo all
I thought I understood the basic principle of piped engines, but I seem to have got myself thoroughly confused. I always assumed that the pipe was simply a quarter wavelength, at the desired frequency (desired revs). I put some figures into the equation V = n x w. V being the speed of sound in inches per second, n is the revs per second of the engine and w being the wavelength in inches (sorry, I can't find lambda on the keyboard!).
You know, its all easy stuff, the position of the first baffle is a node (or is it an antinode? I can't remember!). I know the speed of sound is different in a hot gas than in air at NTP, but let's ignore this for first rough calculation. Take Brett's VF 40 setup, revs approx 11000 rpm and length to first baffle approx 18.5 inches. If you substitute the revs into V= n x w, then I get a w (wavelength) of around 5 to 6 inches. V in inches per second and n in revs per second........................ Right, either I can't do simple arithmetic or I don't understand simple pipe theory (Both of which are highly likely!!).
Leaving aside the fact that I can't do simple physical calculations (onset of senile dementia?) or perhaps I totally misunderstand standing wave systems, I am still confused about stunt pipes. Eveyone talks about the length from the glowplug to the first baffle, but what about the rest of the pipe? Randy's pipes, show that they have a weird shape, and a stinger. It is pretty obvious that the rest of the pipe is there for a good reason. The re enterant at the end of the pipe shouts of early two stroke motorcycle design, intended to limit revs to preserve the integrity of engines with poor metallergy. Talk of a first baffle implies that there is a second baffle........................................oh dear, perhaps I need to retire to a dark room and take an aspirin!
Anyone out there have a clear concise explanation of the intricacies of a stunt pipe?............................Please?
Andrew.
Isn't it great when you find that you don't understand things after all!
