  • July 18, 2025, 09:11:35 AM
Author Topic: Warped wing  (Read 1797 times)
Offline cory colquhoun
Warped wing
« on: July 01, 2017, 04:29:36 AM »
Anybody get any tips on how to straighten trailing edge,the trailing edge on the inboard wing of my  newly built twister slightly bows  , not covered yet
Offline RC Storick
Re: Warped wing
« Reply #1 on: July 01, 2017, 05:02:53 AM »
Steam it straight
Offline Dennis Moritz
Re: Warped wing
« Reply #2 on: July 01, 2017, 12:27:56 PM »
Steam it straight. Make longitudinal (lengthwise) exacto cuts. Lock straight with thin CA in cuts.
Re: Warped wing
« Reply #3 on: July 01, 2017, 01:07:09 PM »
Ok, will give it a go, thanks
Offline RC Storick
Re: Warped wing
« Reply #4 on: July 01, 2017, 01:07:44 PM »
No need for any cuts just a lot of steam and it will get loose, Then warp past the spot you need it and it will relax close to right shape. Steam as many times as needed.
Offline Mike Griffin
Re: Warped wing
« Reply #5 on: July 01, 2017, 03:57:17 PM »
A tea kettle works great for steaming.
Warped wing
« Reply #6 on: July 01, 2017, 04:27:23 PM »
Right. Warp in opposite direction with steam. In my experience wood returns to previous shape after a time. Some method of locking wing straight helps. Monokote and the like will allow shape to lock pretty solid. Some combat fliers are great getting monokote wings to warp straight. Phil Cartier did his magic on something I built. Wing stayed true for years.
Re: Warped wing
« Reply #7 on: July 01, 2017, 05:23:20 PM »
I used Pva glue will this be affected by the steam?
Re: Warped wing
« Reply #8 on: July 01, 2017, 08:24:38 PM »
White glue yellow glue any of the wood glues will soften when heat is applied. Then harden again when cooled. Probably those characteristics will assist warp removal.
Re: Warped wing
« Reply #9 on: July 01, 2017, 08:32:15 PM »
OK.  Everything that's been said is absolutely true, BUT:
1: I would only do the longitudinal cuts and re-gluing if things were really bad and the application of heat did not work, and
2: If the warp isn't bad, sometimes dry heat (like a heat gun) works well -- I find it more convenient
The best solution is to go back in time and smack yourself upside the head before you build in a warp, but no one has figured out how to do that, yet.
Re: Warped wing
« Reply #10 on: July 01, 2017, 11:03:08 PM »
Warp was only slight and boilling kettle did the trick, it is straight for now ,best cover it and hope it stays that way
 Cory
Offline RC Storick
Re: Warped wing
« Reply #11 on: July 02, 2017, 01:39:17 AM »
 Cory
It works even after covered. So no worries.
Warped wing
« Reply #12 on: July 02, 2017, 08:36:36 AM »
Great. What kind of covering?
Offline RC Storick
Re: Warped wing
« Reply #13 on: July 02, 2017, 02:08:50 PM »
Any kind! You can steam a 4x4 with enough steam. It works on foam wings, silk covering, polyspan, silkspan, plywood Just the degree of heat needed.
Re: Warped wing
« Reply #14 on: July 02, 2017, 11:56:31 PM »
      Sig koverall,I'm thinking
