  • July 31, 2025, 07:44:06 AM
Author Topic: What do you think about this compressor  (Read 1257 times)
Offline Willie Johnson
Re: What do you think about this compressor
« Reply #1 on: March 20, 2013, 07:44:23 PM »
Paul,
I buy a lot of stuff from HF.  I don't recommend their air compressors.
Willie
Willie Johnson
AMA 774461
« Reply #2 on: March 20, 2013, 07:51:31 PM »
I had that same model for 10+ years until recently it got a pin hole in the tank. I bought a new one and fixed the old one and gave it away. Paid $90 for it 10 years ago. I ran it a lot.
« Reply #3 on: March 20, 2013, 08:01:18 PM »
Weirdly, that looks just like a compressor.
Offline Doug Moon
« Reply #4 on: March 20, 2013, 11:09:19 PM »
With only an 8 gallon tank it will probably run often while spraying anything for continuous amounts of time.  Just a thought.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #5 on: March 21, 2013, 08:40:33 AM »
I have had one like that for quite a few years from HF.  It has done the job I wanted, even using dope.   Yes it does run more often than a bigger compressor/tank set up.   But, so far the neighbors have not complained about the noise.    For smaller jobs I use my air brush setup.
« Reply #6 on: March 21, 2013, 11:25:52 AM »
Offline Gene O'Keefe
« Reply #7 on: March 21, 2013, 12:53:30 PM »
It's hard to tell from the picture, but it appears to be belt driven (which is good) - no matter what you get, I HIGHLY recommend against getting an "OIL LESS" version....extremely noisy and they do not last long.
Gene O'Keefe
AMA 28386
« Reply #8 on: March 21, 2013, 07:43:04 PM »
It says it's "direct drive", which I'd think would be a lot quieter than belts. It's 120v., which is what I was looking for. I'd say that IF it's made in USA, buy it. If it isn't, I wouldn't pay for it, but I would haul it home if it was free.  y1 Steve
« Reply #9 on: March 22, 2013, 05:44:17 AM »
Direct drive. The larger ones motor runs faster than the smaller 8 gallon one I had for many years. It brings the tank up to 120+Lb faster than the small one did.
Offline bruce fraser
« Reply #10 on: March 22, 2013, 07:14:09 AM »
Something to consider. Most of those cheap compressor are not ASME rated. You do not want to have an air tank blow up. Make sure to get a rated tank. ASME are OSHA required for all industrial uses.
« Reply #11 on: March 22, 2013, 12:01:57 PM »
I ordered one from Costco. If it breaks its going back.
