Yes, the way Fred has it on a profile is the way to go. Seems the airflow over the fuse gets turbulent and causes pressure fluctuations that make the uniflow tank unpredictable on some ships. I had a Ringmaster with an OS 25 on it, hard tank with the uniflow vent just off the tank (on the outboard site of the fuse), this gave inconsistent runs, some great most to lean. Again, after I moved the vent to be clear of the fuse up in the free air stream BOOM solid runs no matter what the weather conditions. As for up wind/ down wind I use 1/16 hole in the end of the vent line (it naturally gets shaped down from the tubing cutter) and I haven't had any real issues.
Best, DennisT
