Today I called Eric Rule to cut one of my Shark 35 profile kits. The profile fuselage is cut from two pieces of 1/4" X 4" that is laminated together by the builder to form your 1/2" wide fuselage....Normally up until now. Because of the shortage of 4" wide boards, Eric is having to cut the profile out of 3" stock and this means there has to be joints vertically whereas when we had 4" wide material this was not necessary. We are joining these pieces in a staggered configuration so a stress riser is not created.
This is the first adjustment that is being made due to shortages, and it looks like more adjustments will coming down the road.
