I have found new motivation since the online build class will be going on soon. I have been working off and on with this airplane since last summer. I did get a few other planes done while this one was waiting its turn. But now, I will have it in dope by the 18th.
I tried something new to me. I made the ribs from 1/4in foam. I did some non scientific bending and breaking tests on the foam and 1/16 balsa. I found that that they both were bendy, and while the foam was less rigid, it would bend lots more before it broke. With the cap strips, upper, lower, leading and trailing edge spars, it seemed strong enough to me. Also, I did not have enough 1/16th to make all the ribs. So I did it like this.
The wing weighs 11.8oz as the pic shows. No dope is applied yet.
The plane partially assembled as shown weighs 21.2 oz
The fues is hollow with 1/32ply as the sides and 1/16 ply as doublers past the trailing edge.
I will have an aluminium pad under the engine to help make the nose a bit more rigid.
I was also going to double up on the silkspan over the control surfaces.
The plane will be finished in Brodak Dope, cause I have enough.
Engine will be my 35FP that was reworked by Len Neuman.
I was hoping to keep it under 40oz, but the wing came out a bit heavier than I hoped. the entire wing weighed just over 7oz before the controls and tips were added.
Even if I go a bit over 40oz, it will still be the lightest big plane I ever built so far.
Its shaping up nicly....
Greg
