The registration is separate from Stunt Hangar. However I recommend you use the same user name and password. So you can remember it. After filling out the form you will receive a email with a temporary password. You must verify your email so use a valid email address. After logging in you can change your password to something you will remember. Use the FAQ on the right side of menu. It explains all auction functions. If you need help make sure to include your user name and email address you used at the time of registration. Other wise I cant find you .
Be careful not to hit enter before you are done,It records your IP address and you will not be able to register again.
