General control line discussion => Open Forum => Topic started by: David_Ruff on November 22, 2023, 07:33:04 AM
Building the Brodak Viking. I am wondering if there should be any engine offset? The plans do not call for it. It does have rudder offset.
Engine offset, 1 to 2 degrees right, 1 degree down. I set every model I have up like that. Read Bob Whitley's article on "Things That Always Work" in a Stuntnews. It may even be pinned on the site here somewhere. As for rudder, make it adjustable, and stat out with just a tiny bit right.
Sounds good. Will try that.
