CLICK HERE--><--CLICK HERE
OS Max III engines
Started by Ara Dedekian, August 24, 2026, 05:21:09 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Ara Dedekian
    I recently found a Max III .35 and .29 in a box of derelict engines. I know nothing about them and wonder if anyone out there knows what the design was intended for. They're baffled with a boss on the crancase cover for an optional pressure tap and have a huge opening in the venturi. Did they come with venturi inserts? Were they performance engines to be used with pressure? I'm currently cleaning them up only to run on the test stand.
  Ara Dedekian
qaz049
#1
Quote from: Ara Dedekian on August 24, 2026, 05:21:09 PMI recently found a Max III .35 and .29 in a box of derelict engines. I know nothing about them and wonder if anyone out there knows what the design was intended for. They're baffled with a boss on the crancase cover for an optional pressure tap and have a huge opening in the venturi. Did they come with venturi inserts? Were they performance engines to be used with pressure? I'm currently cleaning them up only to run on the test stand.
  Ara Dedekian
They're good strong solid engines from the era just before effective mufflers. Way more power that any Fox .35 stunt, and all the cheap glow engines of the early 1960's. Where I live it was not uncommon for modelers to go to a competition with a OS .35 in a Thunderbird for stunt and later in the afternoon take it out and fit it to a combat model. The .29's were often used in B Class Team Racers. On crank pressure in a Voodoo with a Tornado 9x7 the .35's were slightly slower than a FOX .36x.
Yes they did have venturi inserts. Remove the latter and it definitely needed a pressure setup. I mostly  learnt the basic maneuvers with a wide open venturi, on pressure in a combat model. By richening it right up I found that it had a lovely 2/4 break.
I've collected a few off ebay, often in very good condition. I can measure the inserts if you need the info. An ENYA .29/.35 NVA works well.
Steve Lotz
Dan Berry
They are basically the engine of choice for Nostalgia Gas Free Flight. Pretty strong.
Ara Dedekian
  qaz,
    Thanks for all the info, it was quite helpful. Now I have a better understanding of what I have. I can make my own venturies and might make one with a .255" bore if I get around to it.
    The next project out of the aforementioned box is a Duramatic McCoy 29 Super Stunt that I will mount and fly in a refurbished Veco Brave. It cleaned up nicely and is in good condition except for one minor detail; the liner, piston and rod and head are all positioned BACKWARDS, facing the exhaust. Messing with engines that someone else has messed with is really fun!
Ara Dedekian
