What do you use to make propeller molds? Years ago I was able to get Hexcel Epolite 3300 in a 3.5 Lb. kit. having a hard time finding it again so I'm looking for alternatives. Lately I've been using Walmart Bondo. It's fast and gets the job done but it has many drawbacks. I've heard of guys using Devcon steel filled epoxy but I don't know how well it flows or if you can heat it to make it run better. What do you use?
