  • July 21, 2025, 06:28:58 PM
Author Topic: My friend's Trivial  (Read 6916 times)
Offline MarcusCordeiro
My friend's Trivial
« on: March 31, 2013, 01:19:54 PM »
Guys
This is my friend Marlus's Trivial Pursuit. Ro Jett 76.
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: My friend's Trivial
« Reply #1 on: March 31, 2013, 01:27:14 PM »
Guys
Marcus
   Looks really nice!  Need to work on getting rid of the rudder offset, though. At least this one is adjustable- on David's first TP/Star Gazer, he ended up cutting kerfs in the fin with a Zona saw to remove the built-in offset. On 3 different occasions!  Definitely don't need to "manufacture" line tension if you have a 76. It worked dandy with a 40VF.
« Reply #2 on: March 31, 2013, 02:14:28 PM »
Those colors are simply scrumptious!!!  I agree with Brett on the rudder offset - I've had three TP's and all flew/fly great without any.
« Reply #3 on: March 31, 2013, 03:27:32 PM »
Lovely work, Marius.  Hope it flies as well as it looks!  What does it weigh with the clear covering?
Ted Fancher
« Reply #4 on: March 31, 2013, 04:07:46 PM »
Hard to tell.. is the RO Jett running on a pipe?  I have the RO-Jett 76 and a CF pipe.  Wondering if I should take the plunge and order a header?
Robby Hunt
« Reply #5 on: March 31, 2013, 05:36:43 PM »
Marlus is THE MAN!
Online Matt Colan
« Reply #6 on: March 31, 2013, 07:54:41 PM »
Wow that's looks great!!! I agree with everyone above, with the 76, I definitely didn't need any rudder offset in the airplane. Flies great without it
Offline Bob Whitely
« Reply #7 on: March 31, 2013, 11:01:01 PM »
Marius, You are very talented!! I enjoyed the video very much. Hope to meet you one
day.  Best Wishes, Bob Whitely
« Reply #8 on: March 31, 2013, 11:28:50 PM »
 #^ #^ #^ #^ y1
Bravo, Marius!  Some very, very good stuff in that flight.  I was particularly impressed with the inverted flight which appeared to simply sit on the top of the fence all the way round; haaaaard to do that.
I also was surprised at the perspective the wide angle lens gave the flight from the viewers point of view.  Made it look like the whole pattern was flown below 60 degrees.  Fun to watch.
Get that overhead eight straightened out and the hourglass symmetrical and go kick butt, my friend.  Loved it and the music made it "rock!"
Ted
« Reply #9 on: April 01, 2013, 08:12:45 AM »
Thanks for the video and tell him the plane in the pics looks great.
Offline Marlus Lago
« Reply #10 on: April 01, 2013, 08:47:32 AM »
Hello guys! First of all, thank you all for the opportunity of being here. H^^
This is my first post and Iīm very pleased of hearing that you liked my plane, which my colleague Marcus Cordeiro gently wrote spontaneously about and sent some pics.
And even more proud of having received some kind words by master Ted Fancher. Truly, itīs a great honor to hear from you! ;)
I will be glad to answer whatever quetions regarding construction and painting were there.
I consider the comments about the rudder, although I think it is really necessary on top manouvers. I had to increase it during trimming, cause it was not pulling enough, even with the leadouts adjusted and the 76er running towards outside a bit. I think it does play a good role in that part of the semi-sphere.
Regarding master Tedīs question about weight, it was a pretty light construction, but after several clear coats, it weighs around 1,900 grs now.
Iīm running the 76 on a B. Eather 13,75" x 4,5" prop and RJ pipe also, since it was the lightest pipe Iīve seen and needed low weight on the middle section of the plane. The BEīs pipe was heavier, and Randyīs as well. To be honest, Iīve tried both ones and the RJett pipe is simply awesome, not mentioning itīs lighter.
Speaking of this, Iīm kind of getting along better with heavier ships, which in my opinion turn smoother, are more stable and performs better on windy days. The red Trivial you could see in the movie sent from Robby (Thank you Robby, very kind as always!!) is really lightweight (1,670 grs) and I suffered flying it on windy days. Donīt know if itīs only my impression, but itīs the way I think... :P
Once again, many thanks for liking the vid, the comments and especially for Chacón, who first told me I should join this great group, Robby for posting it and Marcus for sending the pics!
Stay healthy and God bless you all!
Bregards,
Marlus
Offline Claudio Chacon
« Reply #11 on: April 02, 2013, 06:52:32 AM »
Bregards,
Marlus
Welcome to the Forum, buddy! It's nice to have you among us. <= And post some pics of that Trivial Fleet of yours!
See you around...
Claudio.
Offline Norvaldo
« Reply #12 on: April 02, 2013, 02:07:42 PM »
Hi.
Just 2 questions:
What is the pipe legth and what RPM is the ROJett launching at ?
I have one newly aquiered .76 with pipe and header which i have not used yet and also a Rojett .67
Best regards
Norvald  Olsvold.
Norvald Olsvold
Offline Peter Ferguson
« Reply #13 on: April 02, 2013, 10:22:23 PM »
Fantastic video and nice plane! At the risk of sounding like I know something I'll offer this tip. My Ampact had great line tension everywhere except on the overheads. I had no rudder offset. PW installed a magic tip weight in it and presto the problem disappeared. I don't think it was much weight but the difference was significant.
Peter Ferguson
Auburn, WA
Offline Marlus Lago
« Reply #14 on: April 03, 2013, 08:56:12 AM »
Cool to know this, Peter! Thanks for the hint. Iīve added a little more weight to the outside wing though.
Hello Norvald, my pipe has been run with 18,5" from the center of the plug to the pipeīs first baffle. RPM is set around 9570 to 9650 revs. Fuel I use is Morgan (green), which is originally 16% oil turned into 22% total. No synthetic added other than the original content, only 1st grade castor. Oh! Last but not least, I had to open the venturi to 6mm, cause originally it was not making much of a difference from my Ro-Jett 67. Now itīs been turn into an angry and thirsty Pit Bull! lol
As a matter of fact, my 67 (stock) powers my other Trivial (blue/yellow/green). It runs fantastic, consistent and just a bit calmer than the 76.
If you need any advice on the 67, pls let me know, ok?
Iīll post the pics of the other Triv soon, as Chacon mentioned previously.
Take care,
Marlus
n~
Offline Allan Perret
  • Proverbs
« Reply #15 on: April 04, 2013, 07:29:31 AM »
Marlus
n~
I have a RoJett67 and will be putting it into service for 1st time soon.
Can you tell me about your setup ?
Using same fuel as mentioned for the 76 ?
Fuel quantity for pattern
Prop
Pipe length
Venturi
Plug
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Marlus Lago
« Reply #16 on: April 04, 2013, 11:54:24 AM »
Hi Allen,
Thanks for asking. My set-up for the 67 is almost the same as the 76, with 18,5" pipe length (B.E. #8), exactly the same fuel, however factory stock venturi (donīt remember the opening now...) and the prop a little smaller, with same pitch: B.E. 13" x 4,5" red. Actually itīs the same prop with the tips cut into measure.
For the plug, I used to have a Thunderbolt w/ bar, but it didnīt last that much. Than, I replaced it for an Enya #3 and it became more economic, I believe due to having more room for oxygen in the chamber. In the 76, I use an O.S. Type F (4 Stroke). Never replaced both plugs ever again. RPM is 9500 also at launch.
Regarding consumption, now Iīm outside of town, so I canīt measure the tanks...  :P but when I return from this trip next week, Iīll post the measures for both.
My impressions:
67 => love the consistency and power of the 67 stock and its fuel economy. I havenīt opened the venturi, it wasnīt needed. I donīt know if opening it, the final result would be close to the 76. One thing is for sure: big fuel consumption increase.
76 => didnīt perform greatly in stock mode; not a difference to the 67. I spoke to Brian Eather and he told me the same, his 76 isnīt powerful as his 67 and also said he tried a lot of stuff. Mine did increase power with the venturi opened. Now itīs a little bit angrier ;D
Well, considering my usage for the 67, I got mine running continuously for 1 and a half year now, and it doesnīt need a single bolt replaced. What happened to yours? What is your set-up?
  • Proverbs
« Reply #17 on: April 04, 2013, 12:21:23 PM »
Nothing happened, I bought it from another flyer who only put about 20 or so flights on it.
I am planning to get it into service this season and since I have no experience with this engine I was looking for some good baselines.
I am planning to use a round plastic clunk tank.  I had a Sullivan R-8 working real good with a PA-65 last year and plan to use the same, unless the RoJett-67 can get by with the next smaller size which is a R-6.
Thanks for sharing your set-up.  H^^
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #18 on: April 04, 2013, 06:45:52 PM »
"snip!"
It was my  pleasure, Marius.
"snip!"
For what it's worth, Marius, I'm a big fan of no rudder offset because of other problems it can cause with respect to yaw trim.  Take this with a little skepticism as I've no experience with the .76  but here's something I'd be interested in trying if vertical and overhead performance isn't as good as you'd like.
I'm not a big fan of real large diameter props and, even if they're working "OK," am always tempted to trim the tips and see what happens to performance.  This would be a bit expensive with the big three blade CF props but if you had a spare to experiment with I'd be very tempted to trim the tips an eighth of an inch apiece; test fly to see if you note any improvement in vertical performance and, if so, trim another eighth until you no longer get improved performance.  The smaller diameter unloads the engine a bit and gives it more breathing room when in hard corners or flying the horsepower maneuvers...verticals, hourglass, overhead and four leaf.
I realize there is a school of thought that believes that more diameter is always better.  I don't fall into that camp and often run engines with less diameter than others using the same sort of power train.  If for no other reason the lesser diameter reduces precession and P-factor effects, both of which effect "yaw" which, in turn, effects line tension which just happens to be the subject at hand.
If you can devote a prop to the test it could provide some dividends and allow you to get rid of the rudder offset which would be a good thing, IMHO!
Ted Fancher
p.s.  I'm embarassed to tell you how much the original Trivial Pursuit now weighs after 22 years of dings, repairs and soaking up oil.  Let's just say it's more than yours, uses a smaller displacement engine and much smaller prop (originally a .40VF with which it placed second at its first Nats) and still can fly very well when the pilot gets his "stuff" in order
"snip!"
Bregards,
Marlus
Offline Marlus Lago
« Reply #19 on: April 05, 2013, 07:34:27 AM »
Master Ted,
Iīm really grateful of having received these precious advice. I consider myself having some good information now, since I often get to be criticized around here for not using 14 or 15 inch props, justified by using a big bore engine. There is certain mood for using European material here, and so settling for large diameter props such as the Rainbows seems to be a general rule. And honestly I donīt have nearby much of qualified arguments to hear and try, so I was a little stuck to my own ways... :/ and since CF props are an expensive material for us Brazilians, we gotta be somehow conservative in trying different things. But now I can follow your steps in a more directional positive path! \o/
Regarding your plane, I take my hat off cause Iīm sure a plane that stands for 22 years and still performs greatly is a winner indeed, so it wonīt be oil and repairs that will bother it! And talking to Robby, he told me once that you and Bob Hunt were kind of improving performance by trying to add weight to certain area of the ship, so Iīm right to have a heavy ship already! ;D
And finally, since I was a teenager I dreamed of someday talking to you, as well as receiving some precious advice or even flying together. Well, now that Iīve built 3 TPs (think I like this plane...haha), I would be honored if you could see any of them. Itīll be a great satisfaction to meet you personally on any champs. If you want to see the other two, please access this link to my facebook album, cause Iīm out of town and donīt have the pics in this companyīs computer.
https://www.facebook.com/media/set/?set=a.1950721520871.2108605.1027617792&type=3
The red one you saw in the vid was the first one (with a PA 61), than last year the blue (RJtt 67) and currently, this yellow one (Rjtt 76).
Hope you likeīm and please, if you have any comments, questions or any stuff I do wanna hear, just "shoot me a line!!"
Tks again
Best regards,
Marlus
Offline dale gleason
« Reply #20 on: April 05, 2013, 11:03:39 AM »
There's some nice things in your video that folks can learn from. "Back-flipping" the prop to start high powered motors with sharp props is talked about a lot....here you show how it is done.  First time I saw it was Bob Gieseke back flipping his big Bear, I thought it was magic. It is a must with large modern engines, they like to start this way, driving the engine through compression on the "flip" is asking for trouble, in my opinion...
Thank you for all the effort for this video,
dale gleason
Offline Marlus Lago
« Reply #21 on: April 05, 2013, 12:15:47 PM »
Hello, Dale!!
Nice of you to notice that tiny detail of starting the engine from the spinner! It sureīs a lot safer and fun to do, since the PAs starts really easy!! #^
Unfortunately I have some close friends who suffered from these carbon blades. Mines, I remove all possible sharpness. And believe me, when itīs cold and rainy down here or even the motor refuses to start naturally, I turn the plane upside down and use the chicken stick. ;)
And thanks for watching the vid!!
Take care
« Reply #22 on: April 05, 2013, 04:01:48 PM »
Master Ted,
Tks again
Best regards,
Marlus
Hi Marius,
I did, indeed, follow your link and loved the colorful TPs!  You sure know how to make them pretty.  when it comes to "colors" us Norte Americanos are running fast to catch up with our friends down south.  I'll send you an FB friend request and you can check out some of the pictures of mine over the years in my airplanes album.  Not as colorful as yours by a long shot but there were a couple of color schemes that you might like.
Re the  prop business.  Be aware I could be all wet as I've no experience with engines bigger than the PA and RoJett .61s I used in my TPs following several years with .40 and .46 OS VFs.  Having said that, however...
Since I'm not a trained student of aerodynamics (just a lowly pilot for nearly 60 years) I've found it beneficial to consider potential benefits of ideas I come up with by thinking in extremes.  In this case, for instance, I'm reasonably sure a 6X3 nylon prop off an .049 would be too small to do a good job and that a prop ripped off of a big Stearman biplane at the local airport would be too bit too big!
This proves to me that props can be too big...or they can be too small.  In this case the extremes are obviously "one of each" case.  Somewhere in between the two you'll start finding props that will, however, do the job, some better than others.  You can extrapolate that "among" those that "can" do the job there is, somewhere in the mix, there will be only a few that really make the plane come alive.  And one is likely to best suit the pilot/airplane team.  Finding your "mate" can pay dividends.
Given adequate power to turn that prop (remember, the TPs have been flown to US championships with everything from .40s to .75s in them) the thing that will make the biggest difference is the prop because it is the interface between the airplane and the medium in which it performs.  There is unlikely to be a vast difference in the "best" prop for a given airplane based solely on the cubic inches that drives it.  The extra cubic inches will work less hard to do so but it is unlikely that they will need a bigger prop to do so.  If they need a bigger prop to run right they are probably too big for the airplane (like putting the big Pratt and Whitney out of the Stearman into a TP...it's obvious that's not the way to go!).
Marius,  I hope that someday we will get to meet and maybe even fly together although my TP log book hasn't been getting much thicker in recent years.  Thanks for building and enjoying the TPs.  It's an honor to have a fine modeler and flier do so.
Ted
Offline Marlus Lago
« Reply #23 on: April 05, 2013, 05:07:38 PM »
Master Ted,
The honor is totally mine!! Such a great fluid and modern design like your TP gives me great pleasure to work in!
Iīm sure I would be amazed if youīd build others. Hope this day and the day weīll meet and fly come very soon!
Canīt wait to see the evolution of the TPs over the years in your pics, as well as exchange finishing results and materials.
And you know what, it all makes sense now. Like you said, if the prop is a little smaller, the engine will be capable of producing more power when needed, especially overhead and vertically. Why didnīt I think of it before??? ???
Iīve tried a 13,5" previously to the 13,75", which BTW did not happen to make any difference... Think Iīll cut it down to 13,25" and will post you the news further.
Regarding the engine itself (Ro-Jetts), back in the days did you happen to make any modifications or use to run them stock, like mine?
Offline Rafael Gonzalez
« Reply #24 on: April 05, 2013, 05:09:26 PM »
Did anyone noticed that they have a C/L area with seats for the spectators and a protective fence? #^ #^ #^ #^
 When can I move there? D>K D>K
Here in MA, any time we fly in a public area with no one around, we have the cops within minutes... HB~> HB~> HB~>
I ONCE WAS FLYING AN ELECTRIC GLIDER AND GOT THE USUAL TOO MUCH NOISE SERMON FROM THE POLICEMAN, THEN I SHOWED HIM MY ELECTRIC GLIDER. HE SHOOK HIS HEAD AND WALKED AWAY. I want to go there MARLUS...
 LL~ LL~
Offline Marlus Lago
« Reply #25 on: April 05, 2013, 06:16:36 PM »
Hello Rafael!!
Well, you are pretty much welcome to come around, man!! You know, this complex is indeed one of the few best (if not the only) stuff we can be proud here... It was built a long time ago and frequently this area is desired to be taken by politics and luckily we still have it available. Itīs located nearby Ibirapuera, the most meaningful park in Sao Paulo.
However, it is tricky to fly-in. Due to the high altitude of Sao Paulo, atmospheric pressure is lower than at a sea-level city. So, itīs like driving on a wet track! Lol gotta have the guts to perform at this track!
Hey, when you said MA, you meant Massachusetts? Cause I lived in Boston a long time ago, but wasnīt involved to F2B at the time... Anyway, feel yourself invited to come over and fly with us whenever you want!! Once I heard Bene saying heīd try to have the F2B World Cup here. So, lets see if this day will come soon!
All the best buddy! H^^
Online Steve Helmick
« Reply #26 on: April 05, 2013, 07:44:51 PM »
 LL~ LL~
The cop probably prefers IC powered models?  LL~ LL~ LL~ Steve
Offline Peter Grabenstein
« Reply #27 on: April 06, 2013, 02:59:28 AM »
Marlus is THE MAN!
Hi
since a few days, this very nice video is blocked by youtube in Germany because music copyrights.
I like to share this video with my CL buddys over here in Germany.
Does anyone has a clue ? ......Gorilla or CA or both,?? grin.
Thanks a lot for your advice.
Peter
I hate pessimists, I prefer optimists.
Impossible is done immediately, miracles take longer.
I don't care who your father is ......... as long as I fly here,
Nobody walks, runs, floats or flies across my circle ......... not even to fetch fish, wine or bread.
Offline PerttiMe
« Reply #28 on: April 06, 2013, 05:28:06 AM »
A version without music would be nice.
Generally, I'm not convinced that adding music makes everything better.
Offline Marlus Lago
« Reply #29 on: April 06, 2013, 08:19:44 AM »
Hi guys,
Sorry it didnīt work for you. Itīs strange, cause our folks in the Eastern side could see it.
Anyway, I have already posted a version without music, which can be found on youtube as well. I think it was filmed in the same day. And itīs funnier!  ;D
Here goes the link:
Enjoy!
« Reply #30 on: April 06, 2013, 11:59:10 PM »
Hi guys,
Here goes the link:
Enjoy!
WOW !!!
Obrigado Marlus for your help.
http://www.rc-network.de/forum/showthread.php/386031-Video-My-friendīs-quot-TRIVIAL-quot
http://fesselflug.phpbb8.de/fotos-videos-f34/video-friend-trivial-t717.html
saludos Peter
« Last Edit: April 07, 2013, 12:24:57 AM by peter grabenstein »
