  • July 20, 2025, 08:12:25 PM
Author Topic: Vector Flaps  (Read 1188 times)
Online Peter in Fairfax, VA
Vector Flaps
« on: September 06, 2022, 03:23:32 AM »
My Vector ARF flaps are really warped and in need of replacement.  They are tapered.  Do I need to taper replacements similarly using a sanding block?
If I understand correctly, the kit wood is 1/4" stock laser cut, but not tapered.  Do the kit plans call for tapering?
thanks,
Peter
Offline Carl Cisneros
Re: Vector Flaps
« Reply #1 on: September 06, 2022, 05:43:18 AM »
Peter;
I would venture a yes.
look at the Brodak site under CL planes and look at both the ARF and ARC offerings.
Carl
p.s. now on the mend from total shoulder replacement surgery 2 weeks ago.
they said I can start to drive again in a couple weeks. :-)
Man, I am tired of re-runs on TV.  LOL
Carl R Cisneros, Dist IV
Control Line RB
Online doug coursey
Re: Vector Flaps
« Reply #2 on: September 06, 2022, 06:24:35 AM »
thanks,
Peter
I HAVE THE ARC MODEL AND THEY ARE TAPERED
AMA 21449
Re: Vector Flaps
« Reply #3 on: September 06, 2022, 06:31:40 AM »
Peter;
Duh.............
I think you meant tapering frm leading edge to trailing edge.
Yes, I am still on my meds.  :-)
Carl C
Control Line RB
Offline Gerald Arana
Re: Vector Flaps
« Reply #4 on: September 06, 2022, 06:48:54 AM »
thanks
Peter; If I were you I'd make two sets of flaps , one set tapered and one not tapered with a square TE. (both removable)
Put the not tapered ones on and see if you can tell the difference, etc.
Good luck, Jerry
Re: Vector Flaps
« Reply #5 on: September 06, 2022, 07:07:01 AM »
Jerry,
You have a point.  There is some thinking that stunter flap TE should not be knife edged.  Also, that flap area should not be excessive.
Removable flaps are possible, though I have not attempted previously.  As I understand it, typical design is Klett/Du-Bro pin style hinges, but with a full flap music wire pin, as well as a hole for the flap horn that is strong, perhaps metal tubing in the flap to accept the horn wire.
Of course I want the plane to fly well.  At present, with the flaps warped about 15 degrees, the plane rolls when you hit it.
thanks,
Peter
Re: Vector Flaps
« Reply #6 on: September 06, 2022, 07:09:04 AM »
Carl,
If the TV re-runs are getting old, you could always arrange an Uber to the NVCL field for the StuntFest contest later this month.  Hopefully, the flying will be entertaining.
Peter
Re: Vector Flaps
« Reply #7 on: September 06, 2022, 07:48:51 AM »
Petr;
I am planning on coming out to our contest for sure.
Carl
Control Line RB
Offline Fred Quedenfeld jr
Re: Vector Flaps
« Reply #8 on: September 06, 2022, 08:05:53 AM »
you should use a wood "plane" to carefully taper the flaps
If using a sanding block do a little on each side constantly flipping it over to make sure you are not creating a warp
getting a taper and keeping the flap straight require lots of patience
Fred Q
Offline jfv
Re: Vector Flaps
« Reply #9 on: September 06, 2022, 09:23:58 AM »
The flaps do not have to be tapered.  A 1/4 inch flat flap will work just fine, if not better.
Jim Vigani
Re: Vector Flaps
« Reply #10 on: September 06, 2022, 09:34:32 AM »
True.  The Vector is a 70's design and everybody tapered their flaps back then so don't expect plans showing different.  I still taper mine but about 1/2 what I used to.  I put a 1/8" FF strip on the backside and taper to that.  Keeps the flap TE straight until the wood relaxes and finds it's "permanent" shape.  Most flap warping comes from tapering wood that is not 100% straight grained as you relieve internal pressure.  I also hollow out the center and fill with "X" pattern ribs but that is another story.  If the flap wood is good and not too heavy (another reason to taper) then leave them flat.  The plane will probably fly better.
