  • June 21, 2025, 12:24:04 PM
Author Topic: 25 folks on line..... and no one in the chat room  (Read 3564 times)
Online Paul Taylor
« on: June 06, 2006, 08:27:52 PM »
I have 30 minutes before bed time.
Everyone jump in the room.
Re: 25 folks on line..... and no one in the chat room
« Reply #1 on: June 06, 2006, 08:29:49 PM »
I am killing time before leaving for work.  DOC Holliday
Offline dennis lipsett
« Reply #2 on: June 06, 2006, 08:35:36 PM »
Tried it isn't working too well for me.
Dennis
Online Harleyman
  • ACE
    • Circle Masters
« Reply #3 on: June 06, 2006, 09:10:35 PM »
I was in for a bit - FUN - gotta do it agin.
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
Offline Bill Sawyer
« Reply #4 on: June 06, 2006, 10:21:50 PM »
I have not been able to get in the chat. It starts to load and then stops about half way done.
Bill Sawyer
AMA 53987
Windancer Models
Offline Leester
« Reply #5 on: June 07, 2006, 01:34:09 AM »
I've had that problem also. I'll put my name down click the enter and get nothing but blank screen.
Leester
ama 830538
Offline Bill Sawyer
« Reply #6 on: June 07, 2006, 05:46:50 AM »
Yes I get the blank screen too. At the bottom there is a block that shows the progression of completion. Mine goes about half way and stops - the same place every time.
Bill Sawyer
AMA 53987
Windancer Models
Willis Swindell
« Reply #7 on: June 07, 2006, 04:19:38 PM »
Mine stops about half way also.
Willis  ???
Offline airbrush
« Reply #8 on: June 07, 2006, 04:27:24 PM »
Willis, I was in there and saw where you entered and left. it was logged on the screen, then again, I'm on *nix, maybe it's a windows thang you guys are experiencing?javascript:replaceText(' :!', document.postmodify.message);
later,
air
  (james)
Offline airbrush
« Reply #9 on: June 07, 2006, 04:31:46 PM »
Here is what I have been seeing :
--> dennis (c-68-82-198-166.hsd1.pa.comcast.net) has joined #stunthangercom
<-- dennis (c-68-82-198-166.hsd1.pa.comcast.net) has left #stunthangercom
--> bfinley (adsl-70-255-166-166.dsl.snantx.swbell.net) has joined #stunthangercom
[airbrush] hello
[airbrush] you there bfinley?
<-- bfinley (adsl-70-255-166-166.dsl.snantx.swbell.net) has left #stunthangercom
[airbrush] I guess nobody has entered the building
--> willisSwindell (pool-70-104-176-241.norf.east.verizon.net) has joined #stunthangercom
[airbrush] hello
<-- willisSwindell (pool-70-104-176-241.norf.east.verizon.net) has left #stunthangercom
--> steveadams (69-173-0-43.albyny.adelphia.net) has joined #stunthangercom
[steveadams] hello
[airbrush] hey
--> Guest4359 (69-173-0-43.albyny.adelphia.net) has joined #stunthangercom
[airbrush] there have been people coming in, but they don't stay, found out why in the "25people online post
[airbrush] is that you frankc?
<-- steveadams (69-173-0-43.albyny.adelphia.net) has left #stunthangercom
[airbrush] wow, nobody is answering
<-- Guest4359 (69-173-0-43.albyny.adelphia.net) has left #stunthangercom
hope that helps,
air
Willis Swindell
« Reply #10 on: June 07, 2006, 07:42:10 PM »
Airbrush
I log on I see peoples name on the right side a small place at the bottom to write something and two words at the end , Say and Act.  the rest of the page is blank.
Willis
Online RC Storick
« Reply #11 on: June 07, 2006, 07:52:56 PM »
Type something in the box and hit enter. The page will refresh. And you will see someone there. :!
« Reply #12 on: June 07, 2006, 08:01:47 PM »
Click on the rectangle at the bottom and type, then click either "say" or "act". Doesn't make much difference. It would be swell if there was a way to tell if somebody's "In Chat" before you bother to go in, yourself. You can log into "Chat", minimize and go back into the Forum and wait. If you hit the "maximize" button on your browser, you can have two small screens up, so can sorta watch chat while you read or post on the forum. And I'm using WindersXP and it works fine. If it "stalls" (half loaded), try hitting the button again to give it a nudge in the posterior.  n~ Steve
« Reply #13 on: June 08, 2006, 02:34:13 PM »
Sounds like you guys need a set time to gon on line and stay there.  My wife's aunt Betty would gon online and send message, then wait until a response.  DOC Holliday
