General control line discussion => Open Forum => Topic started by: Sam Laughery on June 04, 2006, 06:43:55 PM
I've nearly finished my Vector hopefully in time for the Flyin. I've built quite a few planes mostly RC but this is the first one I've buffed out. After all that elbow grease sure hope it flies. Hopefully I'll find out if the rain ever stops. Here are a couple of pics.
Sam
Nice job, it will definatley stand out. y1 y1 y1 y1 #^ #^ #^
hey sam that looks good. and it'll fly.
Thanks Frank. I'll let you know.
Sam
I like the canopy. It's different.
HI Sam
Nice job
the plane looks like it will show very well in th e air and on the ground
Sam,
Sure is a nice looking plane and should be a great flyer! Best of luck!
trcap1
Man is this thing tail heavy. It balanced at about 4 inches back from the LE. Took 8-10 Oz to get it to the correct CG. Anyone else having similar problems with the Vector? My Vector ARF was good right out of the box. If I have to add that much weight I'm going to need a bigger engine. I have an TT 46 I could use but I'd have to trim the crap out of the cowl. Anyone out there have an 8 Oz spinner? ??? ??? ??? ??? ??? ???
You might want to check the accuracy of the recommended cg. My Brodak ARF vector 40 manual specified a CG 1 7/8 inches aft the leading edge. It looked way wrong so I contacted Randy Smith. He said the plane is designed for a cg 2 7/8 to 3 1/4 inches behind the leading edge. Mine balanced 2 7/8 with a Brodak .40 and stock muffler and when I went to a chip muffler went to 3 1/4 inces back. It flies very nicely there.
bob branch
Hi The plane normally balances at 3 inches from the leading edge, this is near the high point of the airfoil.
I have never seen one take 8 to 10 ounces to balance?
What is the weight of the plane?
Regards
Hi Randy,
I appreciate your help. The plane is very heavy. I knew it would be when I was building it and decided to plank the wings and glass the wing and fuselage. I also did some major damage to the elevator and fuselage when I dropped a heavy metal object off of a high shelf onto the plane. I'm sure the repair added weight to the rear of the plane. Fully loaded it weighs 55 Oz. I balanced it again using 3 1/4 inch CG and it required 6 Oz. on the nose. I hope to try it tomorrow as is and see how it flies. Any suggestions?
Sam
HI Sam
I wished I had something better I could tell you, most of these planes weigh 40 to 45 ounces, 55 ounces I am afraid , maybe more weight than the plane can handle and still fly well, what will it weigh when you add the 6 ounces of nose weight?
I can tell you that it is very tail heavy and that almost always comes from way too much finish. Can you refinish and lighten up the rear of the plane?
If not I would suggest flying it tail heavy with a handle that has about a 3
to 3 1\2 inch span.
Let me know when it gets in the air, the plane will fly, I just am not sure how well
Regards
Thanks Randy. I'll let you know how I make out. If the plane was in the 40-45 Oz range and well trimmed, what would you recommend the span be on the handle?
Sam
Hey Sam,
For a first attempt at a stunter for C/L, that's a beautiful job. Good luck with it and I understand your frustration with the rain. We've been getting a lot here in NY also and our back circle at Flushing Meadows Park, looks like a lake front piece of property. The other day when the guys went flying they said there was a duck family swimming in the water.
Yours in STUNT,
Bob "Champione" Lampione
Thanks Bob. It looks pretty good but might not fly as well as I'd like. I'll know tomorrow. If not I'll fly my Vector ARF instead. See you at the Flyin.
Sam
