I'd like a little feedback here. My current flyer was giving me a problem on the second turn of the outside square. The lines would get a little loose after the initial dive and I would have to "jerk" the down control to get the second corner. Not a great feeling. Anyhow, the CG seemed OK. The plane is very stable etc. Anyhow, I experimented with CG since I had tried a number of other trims to correct the loose line problem and nothing was working. I added tail weight and, at first blush, it appears to really help that problem. I initially added 1/4 oz and that, pardon the expression, seemed to "turn the corner" on the loose lines. I added an additional 1/4 oz but the wind came up and I couldn't tell if the condition got even better or remained unchanged from the initial 1/4 oz. I'll try again this weekend.
In any event, the plane is still stable, glides very nicely and the additional tail weight seemed to really help the loose lines on that second turn of outside squares.
What experiences do you guys have with the loose lines and CG adjustments?
Tx.
