Li'l bit more...been busy with honey do's.. Phil
Sorry..false alarm...found tha answer way up in Step 74....Glad I'm not flyin' a jet...... Phil
Ok Leo, got my wife to read the instructions and I'm doin' much better now. Second picture .... after couple glasses of grapes. Phil
Thanks for the compliment Leo. Now a question for you who have completed the kit.When I set up the control linkage according to the plan, I don't have one to one flap to elevator movement unless I change the elevator control rod to the top hole. Is that right? Or should I not have 1:1 elevator flap ratio with this plane. What setup are you guys using? I want to get right because once I close the fuse up it's a done deal.Phil
Still at it.....funny thing what you can forget over the years.....I forgot that when you invert the engine you also have to reverse the NVA...so I drilled the needle valve hole and installed F1 with the fuel tubing hole on the wrong side. All fixed now. Now I need to sand, fill, and give her some nitrate..Phil
