  • June 22, 2025, 11:05:32 AM
Author Topic: wire joiner's  (Read 1225 times)
Offline Bootlegger
wire joiner's
« on: October 31, 2012, 09:22:22 AM »
  Guy's when you are bending your flap/elevator joiner wire what have you found to be the best way to gat accurate bends?
                     Thanks a lot,              :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Chuck_Smith
Re: wire joiner's
« Reply #1 on: October 31, 2012, 10:24:32 AM »
Honestly - I bend the joiners, mock everything up with the hinges temporarily installed and then trace were they need to be on the flaps or elevators with a felt-tip, then build my plywood "clips" and install them.
On a built-up flap I'll leave a 1/2 tip outboard, mock it up and then sand the ends of the flaps to even out any problems. With reasonable care you can get joiners pretty close ( say with .063") by just going slow and using your eyes.
Or lately, I buy horns and design the parts to fit. That's the easiest way to do it. :)
Chuck
« Last Edit: October 31, 2012, 10:59:36 AM by Chuck_Smith »
AMA 76478
Offline Derek Moran
AMA 82617
Offline MarcusCordeiro
Re: wire joiner's
« Reply #3 on: October 31, 2012, 04:46:07 PM »
That is some serious fabrication...
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Allan Perret
  • Proverbs
Re: wire joiner's
« Reply #4 on: October 31, 2012, 05:21:12 PM »
  Guy's when you are bending your flap/elevator joiner wire what have you found to be the best way to gat accurate bend ?
Make a test bend with same wire, tool, and bend sequence to determine take-up.
If for example test bend comes up 3/16" too narrow, add that amount to layout of next bend and you should be real close.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Bootlegger
Re: wire joiner's
« Reply #5 on: October 31, 2012, 05:32:36 PM »
         H^^  Thanks guy's, sure do appreciate all the info... y1
Gil Causey
AMA# 6964
Offline Chuck Feldman
Re: wire joiner's
« Reply #6 on: November 02, 2012, 05:20:10 AM »
I use a pair of vice grips that are modified per Charlie Reeves. The edge of the jaws are rounded so that you can get  a proper radius. Then measure and correct if needed.
Chuck
Chuck Feldman
AMA 15850
