  • July 19, 2025, 09:28:47 PM
Author Topic: Upright Fox 35 on a profile  (Read 1196 times)
Offline Bootlegger
« on: July 04, 2018, 06:30:35 AM »
   What kind of way have you folks found works best to set up an upright engine on a profile fuse, such as Al Rabe did on some of his Mustunt profiles??
  Hope that I made myself clear, and thanks a lot...   :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Upright Fox 35 on a profile
« Reply #1 on: July 04, 2018, 08:08:41 AM »
   Pretty much the way that Al did! If you are going to kit bash a Twister or something like that, you don't even need the Mustunt full size plan, just the magazine page to duplicate the construction. The biggest draw back in my opinion to this type of fuselage is the extra weight in the nose that all of the balsa block needed to fill out the nose adds, so be careful in that respect. Keep it to a minimum. It could probably be done with heavy formers and molded sheet.
  HAPPY 4TH OF JULY!!!
Offline gene poremba
« Reply #2 on: July 04, 2018, 09:36:43 AM »
 I did a trainer for my grandson and used a Dave Brown radial mount. I attached the radial mound to a piece of ply that had blind nuts in it. I tapered balsa blocks to the fuse. It lasted several seasons and a few straight in oops!....Gene
Offline James Holford
« Reply #3 on: July 04, 2018, 09:57:28 AM »
Or this.
Guillows Trainer III for a Fox .35
My dad still has his.
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
« Reply #4 on: July 04, 2018, 10:03:37 AM »
 I like that!.….Gene
« Reply #5 on: July 04, 2018, 11:29:13 AM »
   Yes, the way Al did it, or a radial mount a la the Imitation, both work fine. I have built two like Als (very long ago) and it worked just like a full fuselage. Don't scrimp on the blocks around the leading edge, it still shakes and can shake the nose loose pretty easily.
