  • July 05, 2025, 06:28:56 AM
Author Topic: Universal engine mounting system  (Read 1210 times)
Offline John Craig
« on: May 13, 2013, 12:02:09 PM »
Texas Mounts??
What is the proper way to do this?  Aluminum pad thickness?  Bolt size?    35-45 size   59-60 size?  Is there something better? Easier?
When I was 15, I had an improperly mounted engine come lose & fly right by me. Never again!   HB~>
Offline Dick Pacini
Re: Universal engine mounting system
« Reply #1 on: May 13, 2013, 12:51:01 PM »
Windy Urtnowski has an excellent system.  A similar system is also sold by Brodak.
http://www.windyurtnowski.com/MTRMONT1.PDF
AMA 62221
« Reply #2 on: May 13, 2013, 04:57:59 PM »
I am an admirer of the "New Mexico" engine mount plates publicized by the late Larry Cunninham. He showed a U-shaped slab of 1/8" aluminum. The really important thing is to countersink the bottom side of the plate and mount the engine to the plate with flathead screws, with flat washers and elastic lock nuts on top of the engine mounting lug. I have used simple strips of aluminum for the same objective...works very well.  H^^ Steve
« Reply #3 on: May 14, 2013, 05:54:42 AM »
And using Larry's system of the U-shaped piece you can use different engines if you have several of them made.   You can also do the same with the individual pads.   I think 1/8 inch thick hard aluminum is sufficient no matter the engine size.   I myself do not like the clamping method without a pin going into the engine lugs to keep it in one place if the machine screws get loose.
