  • July 14, 2025, 04:39:53 AM
Author Topic: uniflow tank question  (Read 1077 times)
Offline donald raab
« on: May 05, 2011, 11:04:26 PM »
Tank question.  Just got a Brodak uniflow wedge tank 2.5 oz.  It will go on a Sig akromaster with a cs 15 chinese diesel.
1.  Where to mount it in relationship to the venturi?
2.  Single tube out the bottom.  is this the fuel tube to the engine?
3.  Two bent forward tube out the top.  Which should be capped and the other open?
4.  Which is the input fuel tube to fill the tank?
I go back a long way but not uniflo.
Don
Re: uniflow tank question
« Reply #1 on: May 05, 2011, 11:28:52 PM »
Hi Donald.
The tube straight out the bottom is the overflow. Cap it after filling the tank.
The bent tube out the top closest to the wedge is the line to the engine, or pick-up tube.
The bent tube out the top closer to the flat side of the tank is the uni-flow vent. Also used to fill the tank. Leave it open to the airflow.
Mount the tank with the center of the wedge on line with the needle valve assembly, ( or center of the venturi for profile mounted engines) but be prepaired to adjust it up or down a little for even upright/inverted engine run. If the engine runs richer upright, lower the tank and vice versa.
Offline donald raab
« Reply #2 on: May 06, 2011, 09:00:32 AM »
I definitely had not a clue.  Thanks much for the detailed explanation.
