To the very informative discussion from Reply #7 on...
Stray thoughts:
-- For some engines set fairly rich in 4/2 mode, on a briskly windy day there is noticeable richening of the setting as the model crosses the upwind half of the lap... This can be reduced, but not eliminated, by sleeving the forward facing uniflow entry vent to a smaller ID.
-- Vapor pressure does not seem to make problems, agreed. But we're presuming standard glow fuels, right? I also fly diesels, at times, and just recently have come to believe that the greater volatility of the ether fraction of the fuel and uniflow venting are not nice to each other. I've had problems gettng a diesel - i.e., an engine that supposedly can be set to run the same, regardless, by prop, fuel blend, compression and mixture needle settings - to run consistently and well with a uniflow tank. The heat and vibration conditions, apparently, get the ether "all shook up."
Jim T.'s solution is a one-way valve to prevent the gasifying ether from pumping fuel out the uniflow tube. For him and his ST 15D it works well. I've tried similar, and had less happy results. Recently, in benching a diesel, I saw muchos bubbles in the fuel line while the tank was rigged as uniflow. Shut it down, reconnected the plumbing so that it was single, free-venting type, and Vwah-lah - no bubbles, and the diesel didn't care about a static fuel head change from level to the NVA to over 2" lower - RPM crept up only a hundred or so over 6 minutes!
CONCLUSION: IF vapor pressure in a uniflow vented tank becomes a problem, it will "relieve itself" out the uniflow entry tube.
-- Another thought to keep in mind: The hydraulic layout for the tank, fuel-line and NVA should be viewed in regard to the resultant ("local gravity") direction. The fuel in the length of the fuel line is pretty much at the same "height" from the pickup opening until it turns "up" to the fuel nipple. Yeah, there're pipe friction losses, but they'd be there in a "static tank" condition, too, so they might well cancel out of consideration.
I'll read over these fine posts a few more times, f'r sh'r... Thanks!
