  • July 19, 2025, 04:25:15 PM
Author Topic: Ultrasonic cleaners for engines ?  (Read 1587 times)
Offline Rob Killick
« on: August 24, 2007, 06:09:42 PM »
Hi ,
I picked up an ultrasonic cleaner .
It is timed and has a heater , that reaches 170 degrees F , with a 2.5 liter capacity .
I'm wondering if anyone has had experience with this type of unit , for engine cleaning .
One thing I would be worried about , would be removing the coloring (OS LA's and Irvine) from the crankcases .
Rob Killick , MAAC 33300
Offline De Hill
Re: Ultrasonic cleaners for engines ?
« Reply #1 on: August 24, 2007, 06:54:57 PM »
I go down to the local Dollar General store and buy a cleaner called "mighty orange". It works well in my ultra sonic cleaner. It will remove anodize and paint, though. I doubt if you can find a cleaner that will not remove paint in an hour or three.
When you place an engine into the ultrasonic cleaner, don't let it rest on the bottom. Hang it from a hook or in place it in a basket at least an inch off of the bottom. corrosion will occur if you let it rest on the bottom of the tank.
De Hill
Offline Rob Killick
« Reply #2 on: August 24, 2007, 10:42:12 PM »
Thanks De ,
Aprreciate the info .
Dave Adamisin
« Reply #3 on: August 25, 2007, 09:40:13 AM »
Been using one for forthy years. Great for everything but the ball bearings. Brg's always get "grindy" after some time in the US cleaner.
Offline Garf
    • Hangar Flying
« Reply #4 on: August 25, 2007, 10:35:48 AM »
I used to work in an instrument shop. We used to use a simple soap solution in ours. Then again, we never had things as nasty as baked on castor oil to clean. I wonder how antifreeze would work in one?
Offline Stan Bidowski
    • Winnipeg Perfect Circle Flying Club
« Reply #5 on: August 25, 2007, 02:22:26 PM »
That's a good question.  I use a crockpot with good results as many do.
I also use ultra sonic cleaners ( I have 3 ).  One larger unit has a heater,
but doesn't get as hot as the crockpot on high.  I also thought about using
antifreeze in a Ultra 'S', but haven't tried it yet.  I have used various
fluids/cleaners in it, with mixed results, for many years.
Stan Bidowski  :)
MAAC 17167
Offline Warren Wagner
  • Bradenton, FL
« Reply #6 on: August 25, 2007, 03:25:45 PM »
Stan,
Where did you buy your ultrasonic cleaner?
I've wanted one for years, but they are not your common household item, so I have not found a source other than going to a very expensive chemical supply company and paying big bucks.
Thanks.
Warren Wagner
Warren Wagner
AMA 1385
Offline De Hill
« Reply #7 on: August 25, 2007, 05:20:09 PM »
Get on ebay and type in ultrasonic cleaner in the searchbar. You will probably want  one which will hold 5 pints. Less than $100.00.
De
De Hill
« Reply #8 on: August 25, 2007, 08:50:15 PM »
Warren, the larger ultra sonic cleaner ( I think the brand is L&R )was purchased at a dental supply
company.  I asked my dental technician about a source when I was in for a cleaning.  She offered
an address for a local company in Winnipeg.  I also bought a smaller one there too.  The 3rd one I
found at a flea market by pure chance, for a very good price!  - Check with your dentist.  I also
purchased some cleaning fluid from the dental supply as well.
Stan Bidowski  :)
MAAC 17167
