  • July 12, 2025, 10:02:51 AM
Author Topic: Reyco Hardpoint Handle  (Read 3774 times)
Offline Bruce Reynolds
    • Dayton Buzzin' Buzzards Home
« on: July 14, 2009, 05:57:35 AM »
Line spacing is adjustable from 2.50 to 4.50 inches.
Four extra extensions are included (0.10, 0.20, 0.30, 0.40 inches longer than the standard extensions.)  This eliminates the need to bend your own special-length connectors.  If finer adjustment is desired, simply unscrew the adjuster from the bar and turn in the direction required.  One-half turn of the adjuster equals 1/64".  If you want to maintain your handle bias at zero (or some other small angle), you can make your own extension at whatever length you want.  Just about every modeler already has the tools necessary to perform this simple task.
The handle is also pretty light at about three ounces.
The handle is currently available at Brodak.  List price is $29.99.
Offline Joe Mader
  • Vendor
Re: Reyco Hardpoint Handle
« Reply #1 on: June 12, 2010, 06:12:06 PM »
Just wondered if you know who manufacturers Reyco?
Offline Joe Mader
  • Vendor
« Reply #2 on: June 12, 2010, 07:22:50 PM »
Ty,
Do you know where they are located or how to contact them directly?
Joe
Offline andrew stokey
« Reply #3 on: June 13, 2010, 07:10:21 AM »
Joe,
The handles are made by Bill Reynolds and he at "handleman1 at woh dot rr dot com"
« Reply #4 on: June 13, 2010, 08:36:41 AM »
Hi Joe,
Bill Reynolds is my dad.  If you have any problems contacting him at the above address, you can send me a PM with any questions you may have.  Thanks.
Bruce
