  • July 18, 2025, 08:29:21 PM
Author Topic: Ugly McCoy!!!!  (Read 2747 times)
Offline JamieHolford
Ugly McCoy!!!!
« on: November 18, 2010, 12:54:06 PM »
I remember that someone was looking for one of these McCoys jsut the other day and I cant remember exactly what site I seen it at.
 I threw a 10$ bid on it jsut for the heck of it. Its looks pretty neat.
http://cgi.ebay.com/Testors-McCoy-Glow-Model-Airplane-Control-Line-Engine-/220698033645?pt=LH_DefaultDomain_0&hash=item3362a0bded
If anyones feels like outbidding me then go on ahead. I wont fight it lol
Online Paul Taylor
Re: Ugly McCoy!!!!
« Reply #1 on: November 18, 2010, 01:48:41 PM »
That was the first "Big" engine I ever owned.
Went from Cox .049's to this big monster of a engine. Put it on a Akromaster. I never could get it to run right on my Cox fuel. Ya think that was my problem??? I did not have a clue what I was doing as a kid, and not much has changed. LL~
Offline W.D. Roland
Re: Ugly McCoy!!!!
« Reply #2 on: November 18, 2010, 02:48:39 PM »
Jamie
Those are actually good running engines. A little heavy.
(basicly)All internal parts same as Red Heads except piston is Dykes ring in this later version.
The O.D. of the sleeve/liner is different but can be adapted to the Red Head.
When time allows am fitting up a Dykes ring top to go on Red head case.....I need more hands HB~> HB~>
The size is on the mounting lug but don't see it in the pics.
David
David Roland
51336
Offline Mike Anderson
Re: Ugly McCoy!!!!
« Reply #3 on: November 18, 2010, 03:39:29 PM »
The ebay ad says it's a .19 --
The guy looking for one is in the RCGroups want ads here:
http://www.rcgroups.com/forums/showthread.php?t=1339577&highlight=mccoy
Mike@   AMA 10086
Central Iowa
Offline Louis Rankin
Re: Ugly McCoy!!!!
« Reply #4 on: November 18, 2010, 06:15:54 PM »
No Ty, that was Suzie Rotten C#####.
Louis Rankin
Somerville Tennessee
AMA 10859
Dwayne
Re: Ugly McCoy!!!!
« Reply #5 on: November 18, 2010, 06:27:20 PM »
And her prety pink ###### lol
Great movie  y1
Re: Ugly McCoy!!!!
« Reply #6 on: November 18, 2010, 06:36:24 PM »
  *Some of them* are good running engines. Some of them were terrible and almost unrunnable as they came. That was the problem - you never knew what you might get.
Offline Bill Heher
  • Fix-it
Re: Ugly McCoy!!!!
« Reply #7 on: November 18, 2010, 07:53:53 PM »
 As mah momma used to say..
Old McCoys ( Foxes, Stallions, ...) are like a box of chock-o-lots
Ya never know watt yewll get!
Bill Heher
If it's broke Fix-it
Re: Ugly McCoy!!!!
« Reply #8 on: November 18, 2010, 08:38:17 PM »
I thought it was over on RcGroups.
  Well I doubt I'll win the motor. It was more or less a Novelty bid. Ill buy it but wont use it kinda thing. Would just look good on a shelf next to my Gilbert :P
Offline Douglas Ames
Re: Ugly McCoy!!!!
« Reply #9 on: November 18, 2010, 10:42:45 PM »
I like 'em! I currently have 6 .35's - 5 C/L & 1 R/C.
FYI - the .35 weighs in at 9.5 oz.
Don't judge the compression by flipping, with the Dyke's ring the piston seals under cyl. pressure.
AMA 656546
Offline Allen Brickhaus
  • ACE
Re: Ugly McCoy!!!!
« Reply #10 on: November 19, 2010, 08:31:04 AM »
Art Adamisin told me that many had a molding problem on the back crankcase end  plate.  They had a "bump" that needed to be removed and fitted to the aft end of the McCoy.  This bump caused some crankcase air bleeding and run problems.  Saw Jim Lynch with his pretty Volunteer at the St. Louis MO contest in the summer of 1974 for the first time.  What a great sounding motor he had and a very pretty Volunteer.  Jim is now finishing a new Volunteer for Nostalgia and it will be "so nice".
Allen Brickhaus
Offline George
  • Love people, Use things.
Re: Ugly McCoy!!!!
« Reply #11 on: November 19, 2010, 09:49:33 AM »
...The size is on the mounting lug but don't see it in the pics.
David
Like this...
They were the "Series 21", also known as "Blackheads".
The one in the box has never been run (NIB), the other now has an OS needle...I broke the McCoy one.
George
Edit: Took a closer look at the one on the auction site, it has RJL stamped lightly on the lug.
George Bain
AMA 23454
Re: Ugly McCoy!!!!
« Reply #12 on: November 19, 2010, 09:51:51 AM »
>>No Ty, that was Suzie Rotten C#####.<<
And here I always thought her name was Rita.
I used a McCoy Series 21 40 for a bit a very long time ago.
Re: Ugly McCoy!!!!
« Reply #13 on: November 19, 2010, 12:26:01 PM »
Jamie
David
Hi David,
As to making a "Hybrid".  The sleeve/piston is a direct swap in for the Red Head on the.29.  No mods needed.  The piston/rod is a direct swap on the .35-.40.  The jug from the .40 Series 21 will not fit the Red Head case without machining, but you can simply use the piston/rod.  I have done several each of the .29-.35-.40 so far, and no machining needed.  My first one was dropping a Series 21 jug and piston/rod into a Red Head .29 which I used for a long time in OTS.
The .19 will only work with machining the piston for the  Series 21 wrist pin.  The Red Head .19 has only two bolts holding the jug to the case, while the Series 21 .19 has three (like all the other McCoys).  No easy fix for the .19.
Big Bear
