  • July 17, 2025, 08:52:29 PM
Author Topic: Two planes,What engines  (Read 2719 times)
Offline philip metzner
  • chevyiron420
« on: January 03, 2010, 01:14:27 AM »
  I have two planes near done, my s1a ringmaster, and my magician. My engine choices are, fox.29, two fox.35's, mccoy.35 redhead, k&b.40, fox.40. What would you put on which plane?
Offline Richard Grogan
Re: Two planes,What engines
« Reply #1 on: January 03, 2010, 01:26:52 AM »
Fox .29 on the S1. McCoy 35 red head on the Magician. Of course, it all depends on how heavy you build these.. you may need more power if they are porkers!  b1
Long Live the CL Crowd!
                  AMA 85745
« Reply #2 on: January 03, 2010, 01:54:18 AM »
I agree with Richard.  Good choices for the two airplanes as long as the engines are fit and the models are not grossly overweight.
Big Bear
Offline GEOFFREY
  • Northwest Fireballs
« Reply #3 on: January 04, 2010, 06:48:21 AM »
i would put a couple of them on ebay and save some problems of a fox burp when on a profile. use the money to buy a os la 25 for the ringmaster. the mccoy will do the job on the Magician if it has life left in it.
GEOFFREY L CHRISTIANSON  AMA 824607             DELTA PARK Portland Or.
Offline George
  • Love people, Use things.
« Reply #4 on: January 04, 2010, 09:26:16 AM »
Actually, the Fox burp can usually be fixed by partially blocking the bypass with a stick, and if the McCoy is over the hill some compression may be regained by using  25%-29% all-castor fuel. Think positive...  ::)
George
George Bain
AMA 23454
« Reply #5 on: January 04, 2010, 10:30:18 AM »
I guess being hard of hearing I never noticed the Fox burp on profiles.
  • chevyiron420
« Reply #6 on: January 04, 2010, 12:35:59 PM »
  The tree fox engines were bought used by some of the older boys that flew control line when i was a kid. They didnt fly much and quit. I got them from there cousins many years later. It must have been in the late 60's when they had them. It must have been the early 90's when i got them. They were missing the NVA's but otherwise in great shape. I replaced the NVA's and they seem to run great on the test stand, but i have never had them in the air.
  The McCoy i bought used on ebay. I was missing the drive washer. I got a drive washer out of a hobby shop junk drawer and bored it to fit, i dont know what it came from. When i got the engine it had a old two piece glow plug in it. The compression is outstanding and also seems to run and start great on the test stand. I do wish i had the correct drive washer though.
« Reply #7 on: January 05, 2010, 08:24:07 AM »
Contact Jim Lee at Lee's Machine Shop.  He might be able to make you one.  He made one for my old Green Head K&B Torpedo .35.
Offline Dalton Hammett
« Reply #8 on: January 05, 2010, 12:57:55 PM »
The .35's should do fine, thinking about my Magician,  it does very well with a .32, I believe a .40 would be a bit of ovekill for either plane.  The Magician can be a nice flying plane !!  Best of luck with them.
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
