I think I got this info from that article actually, but to paraphrase what I understood. The theory is that when you are in level flight only one blade is actually pulling, or to think another way, the blades are actually fighting each other, when you put a load on it, as in climbing, then both blades are pulling the plane putting in power. I understand it helps with controling speed.
