Front end of fuse almost done, need to relieve the balsa tripler for the plate mount screw heads, get them final positioned and marked, the glue the trippler on and bust out the sandpaper / files and shape the front end.
Came out nice and stiff, I epoxied the doublers on 1 at a time and sandwiched them between some glass sheets ( old jalouise window slats- handy size to keep around), that way i can check the bond on 1 side before I cover everything up with the other side.
Time to dig the wing out and start the belcrank install on that so when the fuse is done I can finishe the wing and rock-on with final fit / assembly of the controls.
