  • July 21, 2025, 11:51:10 AM
Author Topic: Twin Pathfinder by Gordan Delaney  (Read 5171 times)
Offline ericrule
« on: August 23, 2014, 08:30:15 PM »
This was added to Horby's post about the best profile for precision aerobatic.
As far as Gordan's Twin Pathfinder goes he gave RSM permission to kit the model about 3 years ago. We have done a number of them for people who asked for them but have not yet added it to our line of kits.
If anyone is interested in having one or more please drop me a line at eric@rsmdistribution.com If there is sufficient interest we will do a run of them. For those who would prefer to use electric power I can easily set up the cut files to do the nacelles that way. Just let me know.
Eric Rule
Within 2 days I received 5 messages for folks who were interested in getting one of these models.
For that reason I will be doing a limited production run of the Twin Pathfinder in September. If anyone else is interested in adding their name to the list please  let me know ASAP so that I can put you on the list. I will hold off on the run until September 6th so please let me know before that date.
Eric Rule
eric@rsmdistribution.com or call 951-678-1406 (Pacific Time Zone)
Online Carl Cisneros
Re: Twin Pathfinder by Gordan Delaney
« Reply #1 on: August 23, 2014, 11:32:11 PM »
Eric;
What power plants are guys using on the plane?
Also, I got the order today (dang that was fast).
The Tiger muffler fit the K&B 61 to a T. Not so the Fox.
I beveled the opening on each enc a bit where the exhust enters the
muffler to get a bit better flow in to it.
fired it up in the back yard andsounds nice............. H^^
Carl
Carl R Cisneros, Dist IV
Control Line RB
« Reply #2 on: August 24, 2014, 01:12:24 AM »
Eric;
Carl
Gordy's original had two FP15s and worked really well.  I suspect that two FP25s or LA25s would be OK but might make trimming a bit more difficult.
Two LA15s would probably work OK but I believe them to be a little less powerful than the FP's.
I have two FP15's to put on mine...They may be getting a little harder to find now since they are not being currently manufactured.
« Reply #3 on: August 24, 2014, 02:07:01 AM »
for what it's worth, night try the ASP 21's.
would have to get Lee's Machine shop to do up venturies as they are RC motors.
I have had a couple of those and they are strong running motors. (40 bucks each to boot.)   ;D
Control Line RB
Offline Ara Dedekian
  • Ara Dedekian
« Reply #4 on: August 24, 2014, 06:07:43 AM »
       I couldn't resist ordering a kit after Bob Hunt's testament to the twin Pathfinder.
       I'm thinking of a pair of Fox 15 BB schnuerles since I have some in my "inventory"! I'm running one on a Ringmaster Jr. with Powermaster GMA 10/22 fuel upped to 27% lube. A very consistent runner.
       Don't know yet the weight difference between the FP 15 and Fox 15. Can the twin Pathfinder handle some added weight (assuming the Fox is heavier) without drastically changing the trim and perform, 'as advertised'?
       Ara
« Reply #5 on: August 24, 2014, 01:22:55 PM »
I think John Miller had a couple of 25's on one.  Maybe He will tell us!
My personal guess is that it could handle the power without any problems but The extra weight would require some added weight to balance the CG in the correct place.  That's probably not a real problem either.
I would worry more about getting two Fox 15's to run the same at the same time.  My personal experience with them has not been so good!
I'm also sure the Fox Crowd will tell us how wonderful they are!
Online Howard Rush
« Reply #6 on: August 24, 2014, 01:24:36 PM »
I have flown that airplane, and it's a really, really good stunt plane.
Offline Dick Pacini
« Reply #7 on: August 24, 2014, 04:38:32 PM »
Could someone post a picture of the twin Pathfinder?
AMA 62221
Offline Geoff Goodworth
« Reply #8 on: August 24, 2014, 07:23:03 PM »
Folks, John and Gordan used hot 15s in their twins—not FPs or anything similar. Without searching all my emails and notes from some years ago, I cannot remember what they were but I think one pair was OS—maybe FSRs—but I can't be sure. I do remember John telling me that they needed lots of nitro.
The one we built here in Oz used a pair of LA 25s. I was going to shorten the nacelles a little but John advised me not to because the hot 15s were not all that much lighter than FPs or LAs.
The comic cut of the story is that the builder that I drew the nacelles for made a mistake and put the tip weight box on the top of the wing—and when trimmed, the model didn't need any tip weight.  LL~
« Reply #9 on: August 24, 2014, 08:57:38 PM »
Hmmmmm...
The one we flew here in Tucson had two FP15's.  They probably had a little extra nitro in the fuel because Tucson is 2400 ft ASL altitude.  But....I'm absolutely sure they wer OS FP 15's.  They did use other engines later but I'm fairly sure they weren't anything really special.
Offline Gordan Delaney
« Reply #10 on: August 24, 2014, 09:52:08 PM »
Geoff,
the only engines I ran on the twin Pathfinder was and still is FP .15 teens.8 3/4 Dia. and 4 inch. pitch APC props.
Thank you
Gordan Delaney
Builder owner of the Twin Pathfinder
Online Brent Williams
« Reply #11 on: August 25, 2014, 02:42:48 AM »
« Reply #12 on: August 25, 2014, 05:10:04 AM »
Thanks for clearing that up Gordan. I was relying on my memory from before John had his accident and I'm not sure where I would find all the correspondence from back then.
Cheers, Geoff
Offline Brad Smith
« Reply #13 on: August 25, 2014, 10:50:52 AM »
Eric i would be interested in one how much would the kit cost?
Brad smith AMA780054
Offline Brian Gardner
« Reply #14 on: August 26, 2014, 12:23:33 AM »
Good on ya Eric HIHI%%
Offline ericrule
« Reply #15 on: August 26, 2014, 08:53:56 PM »
For all who have asked I should have final pricing calculated by early next week. I have had to make a couple of corrections to the AutoCAD file so that the parts will fit correctly.
Based upon what most respondents have said we will offer either a full kit or a short kit (short kit has no block, sheet, sticks or hardware).
Eric Rule
Offline WLGeorge
« Reply #16 on: August 26, 2014, 09:04:01 PM »
Interested depending on price and kit type.
