  • July 04, 2025, 12:15:38 PM
Author Topic: tubing material between header and tuned pipe  (Read 1344 times)
Offline Jared Hays
« on: August 03, 2021, 10:45:54 PM »
What and where do I find the light weight hose are you guys are using to connect the exhaust header to the tuned pipe.  The section on my OS 40 VF split all the way length wise down the hose.
Online Dennis Nunes
Re: tubing material between header and tuned pipe
« Reply #1 on: August 04, 2021, 03:05:56 AM »
Hi Jared,
A couple of years ago I was able to purchase a length of some 3/4" ID High Temp Silicone Tubing from Radical RC. They have various diameters and it appears they still carry this, see https://www.radicalrc.com/category/Exhaust-Couplers-542 for further information.
Dennis
Offline Perry Rose
« Reply #2 on: August 04, 2021, 05:31:11 AM »
The tube used to build folding outside chairs with plastic webbing is perfect for it.
« Reply #3 on: August 04, 2021, 07:42:57 AM »
Jared I go to O'Reilly auto parts and buy a double wall silicone high performance heater hose they sell.  It's a little bigger around but stands up well to the heat and pressure of my .76s.  It's pricey but worth it I'd say.  The piece I bought last year was about $15 a foot.  You'll need to replace it after maybe 200 runs.  At some point it can start to leak between layers but it still outlives anything else I've tried.
Offline Donald Main
Offline Jim Svitko
« Reply #5 on: August 04, 2021, 09:17:13 AM »
If you can't find it from local retail outlets McMaster-Carr has it.
« Reply #7 on: August 04, 2021, 01:31:43 PM »
Aero Products is where I've gotten some. I'd imagine RO-Jett also has it, but I haven't gotten any from Dubby. I also haven't had to replace any in about 10-11 years of running mostly piped engines. I must be doing something wrong?   ;) Steve
« Reply #8 on: August 04, 2021, 05:11:42 PM »
Directly proportional to fuel expended... :!
« Reply #9 on: August 04, 2021, 08:13:17 PM »
   I had my first-ever-in-32-years failure of the coupler at the NATs this year. Just blew it right in half. The tubing was about 32 years old, too.
Offline Jared Hays
« Reply #10 on: August 04, 2021, 09:52:26 PM »
Thanks guys!
