  • July 18, 2025, 12:35:15 AM
Author Topic: tubing bender  (Read 1344 times)
tubing bender
« on: October 30, 2020, 10:20:39 PM »
Hey!
Does anyone make a good 1/8 inch OD tubing bender.  I seem to have lost all of mine (or lent them to someone who forgot where they came from).  Truthfully I don't really miss them because the ones I had didn't work very well anyway.
I've found a great number of really good ones that start at 1/4 inch tubing and as you all know they do not make them for our typical applications (stunt).
Offline pmackenzie
  • Pat MacKenzie
Re: tubing bender
« Reply #1 on: October 30, 2020, 10:41:50 PM »
These little things work pretty well, I think Harry Higley made them originally.
(I have one somewhere   ;))
https://www.gizmomotors.com/online-store/bnd018-biso-bender-1-8-3-32
MAAC 8177
Offline John Leidle
Re: tubing bender
« Reply #2 on: October 30, 2020, 11:48:47 PM »
  Randy,
  I have  had some fair fortune with the  Du Bro  785 and there is a more professional type on Amazon I think I have one in my basement.  Amazon has several.  Also a few years ago I discovered the use of Refridgeration copper tubing it's very pliable comes in a coil 12" diameter maybe $.50 per  foot.
       John L.
Offline Peter Grabenstein
Re: tubing bender
« Reply #3 on: October 31, 2020, 12:06:02 AM »
The yellow one is Graupnerīs and
the black,brass wheel ,chrome handlebars works perfect to me which was a "buy now" bay found.
Next time I will test K&S bending 1/8 inch / 3mm OD copper tubes.
Peter
I hate pessimists, I prefer optimists.
Impossible is done immediately, miracles take longer.
I don't care who your father is ......... as long as I fly here,
Nobody walks, runs, floats or flies across my circle ......... not even to fetch fish, wine or bread.
Offline Dave Harmon
  • Tulsa Glue Dobbers C/L and R/C Clubs AMA 5053
Re: tubing bender
« Reply #4 on: October 31, 2020, 04:57:27 AM »
Du-Bro makes 2 sizes of tube benders. I use em' to make tank plumbing.....works great.
Copper tubing inside the tank and annealed brass (K&S blue pkg) for Uniflow manifold (side of fuse).
Offline ericrule
Re: tubing bender
« Reply #5 on: October 31, 2020, 10:26:07 AM »
Hi Randy;
If you are bending brass or copper tubing that you obtain from one of the hobby suppliers like K&S Metal you can eliminate a tube bender by "annealing" the tube. You can do this simply by gripping the tube with a pair of pliers and heating the tube using a Berns-O-Matic torch. Just get the tube red hot and then allow it to cool down. This will anneal the metal and allow you to bend it by hand or with pliers easily with out any crimps occurring. When I was building the GRW fuel tanks I purchased only annealed copper tubing since there were a large number of complex bends that needed to be put into the tubing.
Hope this idea helps
Eric Rule
Offline Dave Harmon
Re: tubing bender
« Reply #6 on: October 31, 2020, 10:51:52 AM »
Thanks Eric.....I forgot about the torch.
