  • July 18, 2025, 07:33:05 AM
Author Topic: Tube muffler  (Read 1362 times)
Offline Brent Rogillio
Tube muffler
« on: October 28, 2018, 06:24:39 AM »
Hey guys where can I get a tube muffler super tiger 51. thanks
Offline Manuel Cortes
Re: Tube muffler
« Reply #1 on: October 28, 2018, 10:30:01 AM »
Hi all.
Any Merco, old or "modern" one will fit.
ST 46 and 60 are a match.
Aftermarket supliers as Randy or Big Art, even better……
Kind regards.
Manuel.
Re: Tube muffler
« Reply #2 on: October 28, 2018, 10:57:36 AM »
Tried Randy he does not have any
Offline George Truett
Re: Tube muffler
« Reply #3 on: October 28, 2018, 11:20:52 AM »
If it is the new style ST 51, the muffler from my cast case Ro-Jett .61 worked on mine.  They list at $50 (or they did) and are well made.  Check with Dub and see if he can fix you up.  There is also Scott Dinger but last time I wrote I did not get a reply.  George T
Offline James Holford
Re: Tube muffler
« Reply #4 on: October 28, 2018, 12:16:03 PM »
Scott Dinger would ve the way to go In my opinion. I emailed him bout a muffler and got a response back bout a week or so later.
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re: Tube muffler
« Reply #5 on: October 29, 2018, 05:48:01 PM »
The Magnum - Royal  / Thunder Tigre 46 ones just about go on , if the G 51 holes are breezey , a bit worn . C-C is about 1 mm off ,
tho theyre still big ugly heavy things .
Ive drilled and tapped a bit of Du Bro Ex Extn , 1 1/2 long , Two Patterns , outside for OS Jetstream , Inside for ST 51 , 60, 46 etc .
So any muffler bodys kinda adaptable , with a few tools & taps .
Re: Tube muffler
« Reply #6 on: November 06, 2018, 05:54:23 PM »
My recollection is that I took the one off my ST G.51 (a Randy Aero CNC Tube-type with 4-40 bolts) and bolted it right onto a Magnum XL .53, so Matt's assertions should be at least half right. I don't have a Royal .45, but do have some TT .46 Pro parts around the shop, someplace.  D>K Steve
Offline TigreST
  • TigreST
Re: Tube muffler
« Reply #7 on: November 06, 2018, 09:34:26 PM »
Randy Smith unit picture here on the ST-51 Block Head:
Very nice and very light.  Availability may be an issue.
Tony Bagley
Ontario, Canada
