  • June 25, 2025, 11:25:45 AM
Author Topic: ST G21 35 ABC sets for the combat guys  (Read 715 times)
Offline Brian Gardner
« on: May 03, 2019, 11:33:28 PM »
Ok Fellas,
I've had a couple of requests for another run of ST G21 35 ABC sets for the combat guys. These are the flat top piston version.
Please state if you would like to reserve a set and we'll see if we get the numbers to do a run of them.
Brian
Online Howard Rush
Re: ST G21 35 ABC sets for the combat guys
« Reply #1 on: May 03, 2019, 11:44:43 PM »
Ok Fellas,
I would like at least one set, please.  Might the exhaust be a bit higher than the original?
« Reply #2 on: May 04, 2019, 12:19:00 AM »
Yeah I would agree with the higher exhaust.  Howard probably has the numbers...If not I have one I could measure or send to you!
« Reply #3 on: May 04, 2019, 12:29:09 AM »
Yes, can do higher exh timing if that's what is wanted.
I need a sample engine, and either the exh timing numbers you want or a dimension above bottom dead center
« Last Edit: May 04, 2019, 01:09:58 AM by Brian Gardner »
Offline Tom Walker
« Reply #4 on: May 04, 2019, 08:20:38 AM »
I would like to order 3 sets. Thanks.
