  • July 13, 2025, 08:03:43 PM
Author Topic: Triming Question....Wing Waggle  (Read 15935 times)
Re: Triming Question....Wing Waggle
« Reply #50 on: November 03, 2016, 03:48:17 PM »
Back to Tim's original issue (remember that?), I am hesitant to add anything to the advice you've gotten from the West Coast Varsity, but I will, of course.
Looking at the picture, I see what appears to be an adjustable tab outboard of a flap.  If the moveable part of the flap aligns with the adjacent fixed part on one tip at a different flap deflection than it does on the other tip, I would expect a little roll or yaw moment increment whenever the moveable part moves past the fixed part on either wing.  A quick way to tell if that's the culprit would be to put a fence between the fixed and moveable parts to remove the discontinuity.  Lots of people have such a flap configuration without a problem, but I've seen trouble from it on a former local yokel's airplane.
Edited to add a link to show how out-of-date I am: http://grammarist.com/spelling/movable-moveable/
« Reply #51 on: November 03, 2016, 03:58:19 PM »
...it could be simply a design issue with the wing tips or too aggressive tip airfoil compared to the root making the tips sensitive to turbulence.
I doubt it. Despite modeling myth, airfoils have the same lift curve slope at low angles of attack.
Offline Reptoid
« Reply #52 on: November 03, 2016, 05:51:22 PM »
I wasn't picking on a typo.  The CG is  about 1" farther forward on my electric Impact than on my last IC Impact, and the leadouts are 7/8"  farther aft (relative to the wing TE) on my electric Impact than on my last IC Impact.
These discussions always cause somebody to point out (never more than qualitatively) that fuel has an effect on IC-powered airplanes' CGs.  Yes, we have taken that into consideration.  On my plane, half a tank of fuel moved the CG forward .42" and up .01".
It's a mystery.  I have a couple of hypotheses as to why the leadouts need to go back so far on electrics, but they are too bizarre to admit in public.
(Edited to split a poorly written paragraph in twain.)
Edited again to apologize to PW for not noticing that he said almost the same thing above
Howard;
   Just curious...........Are you running CW or CCW propeller rotation?   If you've flown both, did it have any significant influence on the CG or LO locations?
       Don
       AMA # 3882
« Reply #53 on: November 03, 2016, 06:50:45 PM »
How the heck does it seem that?
Well I can take one of my airplanes in good trim with a .61 in it.  I can add 1 ounce- or even 1/2 ounce and can feel the airplane getting nose heavy and sluggish to turn.  I then can remove the .61 and the added weight, drop the .76 in and the airplane responds just like the .61 without added weight- just a noticeable addition of power in maneuvers.  That's been pretty cut and dried for me.
The other issue I've convinced myself of the same way- trial and error with way too many design configurations over the years.  If you want the most lift and tightest turn then you start shoving that tip high point forward and holding thickness toward the tips.  The down side to that is the rough ride you get in anything but perfect air.  However if you pull the high point back and taper your percentage the airplane is overall smoother and gets through rough air better though sacrificing pure lift and turn.  Like most everything a compromise is likely better.
« Reply #54 on: November 03, 2016, 07:02:58 PM »
CW now (looking from the back).  I regret that I forgot the effect of prop direction on CG and leadout position.  I'll have to look at the notes.  Whenever I'd switch, the whole thing had to be retrimmed, so it was probably awhile before I got to CG.
Offline Tim Stagg
« Reply #55 on: November 04, 2016, 10:05:37 AM »
I always find it interesting how the topic of the post changes as the chain of responses grows in number. Kind of the similar to the old test of whispering a short story to the person next to you in a circle of people and as the story comes back to you it is not even close to what was started.
Any whoo....all of this discussion is much appreciated, I have many ideas of things to look at the next time I can get to the field...if the weather and my job every cooperate.... something to be said about retiring  y1 y1 ahhhh some day.
The most interesting thread out of this discussion seems to revolve around CG and leadout position...I cant wait to try out these theories. I guess the biggest thing that is puzzling and also probably what interests me the most about control line is how very different  2 models can be trimmed to find the best balance...there is definitely no one size fits all...... just when you think you have things figured out  HB~> HB~>
I want to thank everyone for their comments. I will post results to some of these ideas as soon as I can fly the darn thing again....this weekend does not look good at the moment so it may take a couple of weeks to let you know what I find.
Once I get this issue tamed I have to reinstall the wheel pants which I took off thinking some misalignment with them...or aerodynamic force caused by them was my problem......
Super Chipmunks need to have wheel pants to look the part....but they are a pain ~^
Tim Stagg
Offline Igor Burger
« Reply #56 on: November 04, 2016, 10:21:43 AM »
Not playing a gotcha game.
Exception to the rule perhaps?
What if THAT is the rule and not the exception?  VD~
« Reply #57 on: November 04, 2016, 10:24:44 AM »
Only for wings of infinite span.  Low aspect ratio wings have a smaller lift curve slope; I suspect that for any wing that doesn't have a perfect Prandle planform the lift curve slope at the tips is lower than at the root -- it pretty much has to be for the whole planform vs. aspect-ratio thing to work.  It would follow, then, that a tip that effectively suppresses vortexes would be more effective, i.e. it would have a larger effective chord, which would mean it would have a lift curve slope that's closer to that of a wing of infinite span.
It may also be that a tip that has a sharp edge responds differently to air that's not perfectly normal to the span than a rounded tip, which would translate into a different response to gusts.
Offline Igor Burger
« Reply #58 on: November 04, 2016, 10:31:07 AM »
I'd like to see how much the rudder moves on that one at 10 degrees up and 10 down. What it does at 45 degrees doesn't matter, because you can't use all that during a normal corner.
Graphs have been made from in flight data before. I'd like to see one, with a second curve for the rudder travel. I'd bet that Igor probably has that info.  H^^ Steve
That rudder is at 20 degrees in neutral, and goes 20 degrees right and 15 degrees in (from neutral).
However those +/- numbers do not mean too much since you do not know size of rudder, prop gyro moment etc.
And controls travel is limited to 27 degreees. So it is measured at its max deflection.
Offline Igor Burger
« Reply #59 on: November 04, 2016, 10:42:21 AM »
What I think would be great theater would be to sit in the press box while Brett and Igor fly each other's airplanes a few times and then interview them afterward as to their impressions...positives and negatives.  I've never flown Igor's obviously very capable machine (although I've marveled at the large deflections of his rudder) but have flown Brett's several times and been enormously impressed with its state of trim and uniform response to inputs.  I'd pay to hear them discuss their impressions of each others' ships.
I never flew Bretts model, but I think I can imagine, as I also had IC models with such configuration. Model can be very well trimmable with minimal LO offset as well with extreme offset (I know you will not agree and you will and you also did write theory against, but it simply so as we can see :- ))) ). So I belelieve his or your or any other top pilot model will fly well without troubles. The point of that LO vs rudder offset is that electric models ALLOW do tricks which you cannot do with IC because the fuel delivery will be so corrupted that you will say that it is simply wrong, however they work well on electric :- ))) ... they show advantage in extreme conditions, so pilot will probbaly not see it in first flight, may be he will see them later, and may not at all, but he will see it clearly when he goes back to old model :- ))
« Reply #60 on: November 04, 2016, 11:15:59 AM »
   Yes, but having flown dozens of airplanes with similar trim, I can make a pretty good guess.  It's very close to how the Impactarossa was set, which had some different parameters, but not different enough to matter to this question. The biggest difference is probably that the Max Bee has very little passive yaw stability for the same reasons I mentioned above, and, the fin/fuselage/rudder combination has an unusually low aspect ratio even by "59 Caddy Tailfin" standards, so it takes a lot of offset to get it to do anything. Unlike, say, my airplane, where 1/32" of rudder deflection has DRASTIC ill effects.
    Igor is trimming his airplane to not fly tangent to the circle. If you want that, then do it his way.  I would very strongly suggest that if you want to do it that way, you make some provision for rotating the principle inertial axes of the airplane to match the yaw angle. The fact that there are maybe 10 people reading this that know what that means, and maybe only 3 people have actually tried experimenting with it, indicates what I think the issue is going to be. My experience has been that virtually no one can manage to make it work Igor's way, and those who tried ended up in the 10-gallon-a-month club, but it's no skin off my nose.
    If you want to fly tangent to the circle, then do it my way.  You certainly DO NOT NEED to manufacture additional line tension with any modern power system and otherwise reasonable tail volume/CG/flap effectiveness. But it's not one of those "little from column a, a little from column b" issues, the concepts are utterly incompatible.
Offline Igor Burger
« Reply #61 on: November 04, 2016, 11:28:57 AM »
The biggest difference is probably that the Max Bee has very little passive yaw stabilit.
Exactly, that is the point :- )) that is how was fuselage designed :- )) ... and why it needs Rabe rudder ... and also why its deflection needs to be almost symmetrical right and left.
However I do not think it is difficult to trim ... especially if you ignore (or better if you never learned) some rules which does not apply in this case. There are many people who got to very good trim also without me.
Offline pmackenzie
  • Pat MacKenzie
« Reply #62 on: November 04, 2016, 05:08:35 PM »
And controls travel is limited to 27 degrees. So it is measured at its max deflection.
Just to be clear :), does that mean the deflection varies from 5 degree right at full up elevator, to 20 degrees right at neutral, to 40 degrees right at full down?
Pat MacKenzie
MAAC 8177
Offline pmackenzie
  • Pat MacKenzie
« Reply #63 on: November 04, 2016, 05:14:07 PM »
I would love to ear your (or any ones) theories, no matter how bizarre.
There clearly must be something to it, just based on what is in this thread. It does seem like rather an extreme change. (Both the CG shift and the lead out movement)
Could it be that Igor's big rudder offset  and this big change in leadout position are just two different ways of getting to the same point?
Pat MacKenzie
MAAC 8177
« Reply #64 on: November 04, 2016, 06:46:31 PM »
      It may be easier to understand from a "electric lets you get away with..." perspective rather than "electric requires you to..." but I certainly can't see the mechanism or why it might be different.
Offline Brent Williams
« Reply #65 on: November 04, 2016, 07:07:50 PM »
Here is a picture of Igor's Max Bee which shows the deflection of the Rabe-rudder.
« Last Edit: November 05, 2016, 02:23:03 AM by Brent Williams »
Offline Igor Burger
« Reply #66 on: November 04, 2016, 07:19:38 PM »
Yes, 40 at full elevator down.
Offline Igor Burger
« Reply #67 on: November 04, 2016, 07:27:35 PM »
I do not think it is too bizarre and I wrote it few times, firs time on Stuka, but last time I tried to find it I failed, so I am not going search again, I think it was deleted at some database accident or what. And I am also not so good in text visualizations like Ted ... but I will try simple question:
You have 2 identical models. One is trimmed yawed out and one is yawed in. You fly figures on downwind side of circle and strong wind is blowing from your back. Model has some fuselage area and that area acts like a turbine blade. What it does with first model, what second and which one you will fly rather?  8)
« Reply #68 on: November 05, 2016, 01:56:42 AM »
That is a wing planform effect. Lift curve slopes of different symmetrical airfoils (2D wing cross sections) are the same near zero angle of attack (or zero lift), and I thought Tim S.'s problem was happening in level flight, in which case the wing would be at near zero lift, hence no airfoil would be more "aggressive" than another.  I read Tim's original post again.  He didn't specify level flight.   Maybe you could pick a tip airfoil that operates on a part of the lift curve where lift is petering out while the root airfoil is still in the linear range.  Maybe that's what Dave was writing about.  I started writing this paragraph to say that Dave was full of beans, but now I think he might have a good idea.  I still think he's full of beans about a prop turning the same RPM moving more air with one engine than with another.
« Reply #69 on: November 05, 2016, 08:08:04 AM »
That is a wing planform effect. Lift curve slopes of different symmetrical airfoils (2D wing cross sections) are the same near zero angle of attack (or zero lift), and I thought Tim S.'s problem was happening in level flight ...
I thought you were commenting about Dave's comments about wind gusts.  We're having too much fun with this thread.
I suspect that it's either yaw or your flap-weirdness thing.  Our toy airplanes do have an under-damped roll response (I've got data captures to show it!), but it must be easy to keep from exciting it or every plane we flew would be rocking and rolling all over the circle.
« Reply #70 on: November 05, 2016, 08:39:56 AM »
Is this your info on L.O position/yaw that you were referring to?
Quote from: Igor Burger
Posted on SSW By Igor Berger. A rather interesting approach and runs contrary to some people's opinion.
 http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=130453&mesg_id=130453&listing_type=search
Yaw and leadouts on pictures after all"
Fri Dec-03-04 03:55 AM
           I see my texts are not very clear, so I did some pictures. Hope this will show what I mean. I do not know if my ability to make self explaining pictures is better than my English, but I hope all together will be enough to understand what I mean after all.
So first of all usual understanding what is happening here.
I assume:
1/ Model is tangent to the circle
2/ fuselage & engine has no side aerodynamic forces
3/ lines are outside of wing
4/ bellcrank (BC) is at (CG)
Here is Ted’s visualization from "Bellcranks and CGs redux":
We have dragy lines and moving mass point CG at end of them. Centrifugal force of CG makes tension in lines, so they tend to be straight, but drag makes its usual curvature.
So let’s call the centripetal force Fc. The line drag of lines Fd. It is clear, that stable situation is, if the angle makes another force Fy which is in size equivalent to Fd but with opposite orientation. All is on pic1.
Static (flat) theory tells us where to put lines in leadouts to keep tangent position of fuselage.
So we know the shape and we can convert the CG point to real model and fix lines on place, which will match actual position of lines. Nothing happens. Line drag is counterbalanced by centrifugal force of CG to LO position and forces are balanced. Pic2.
Now assume that we have the same model and we fly overhead. The shape of lines curve is different, because the force FC is less gravity FG. The drag is the same. It means lines are more round. Pic3.
Therefore if LO is in wing fixed on the same place, the nose will yaw inwards. That is happening because CG position is not aligned with LO position and therefore any change in that force leads to yawing. Pic4.
Such a model is not flyable, so “flat” theory cannot work for aerobatic model. … at least at those conditions over.
Now another try.
Assume that we have little bit functioning rudder and it makes constant force Fr on tail. Tail is of the same length as wing. So that force is permanently yawing nose out and thus inboard tip forward. Just opposite than the line drag Fd is. Pic5.
It means that it is the force, which counterbalances line drag instead of CG position. If we want reach no friction in LO, we must put BC far forward, but we know that BC position has no effect to yaw and thus we can live it in CG.
Both line drag and also force on rudder are aerodynamic forces and every change in speed has proportional effect to both of them, so they are in balance at every speed. It means that CG can stay aligned with LO not making any yaw.
As the CG is aligned with LO and not making yaw, then also variation in line tension does not make any VARIATION in that nonexistent yaw. Aerodynamic forces are still in balance, thus also if curvature of lines is different, the resulting stable orientation of fuselage still tangent. Pic6.
We can fly overhead or strongly pull handle and model will still keep its angle.
It is not only CG or (exclusively) only rudder what can balance the line drag. They can work together. Assume the rudder is little smaller and its effect is too small for line drag. Its force is not enough, model tends to yaw in, but we can put lines little back and give CG chance to balance the rest. No problem, but it will make lower line tension overhead.
Opposite situation – if rudder is stronger than necessary, it will lead to opposite situation. We will move leadouts FRONT, CG will fall aft of LO thus not allow outboard yaw caused by excessive rudder force (Fr>Fd) and we are still at tangent position. But lack of line tension will point nose OUT … Dick, are you watching? No gismo, no screws, no tricks, just simply proper design/trim. It means LO moved forward will improve line tension overhead – sounds familiar?
I am not calling for any change. We are able trim models and they fly well. I am only explaining what is happening here. So if we use calculation in hope that “flat” theory is proper and works also for our stunt models, then we simply get situation on pic 2. But we fly on circular path and that makes forces permanently yawing out. The CG can in that case fall to in-flight level of LO, or front of or aft of LO. That situation is on Pic 7.
So the rudder, LO position can very effectively place CG on proper place making that proper response not allowing too much yaw, but also keeping good tension overhead. Pic 8 shows detailed configuration. Fvr is variation of line tension and it gives idea what is its effect on yaw.
Offline Igor Burger
« Reply #71 on: November 05, 2016, 10:16:36 AM »
YES Brent!!! That is. I see it is still on stuka, but pictures are lost.
Well I see it is already 12 years :- ))
Online Paul Walker
« Reply #72 on: November 05, 2016, 12:48:54 PM »
Are you now going to show the difference between IC and electric?
Static solutions are nice, but don't explain the difference.
« Reply #73 on: November 05, 2016, 03:49:05 PM »
    I have no idea why the CG needs to be (or can be)  different. I also only have weak arguments for the aft leadout position (although I think most people are not actually running a static yaw offset).  But I am concerned with the rest of the theory and I have seen nothing since to change my mind, far from it. The original was in 2004 on SSW, as I recall.
     The point I made before and still see is that there are a few things missing from Igor's illustrations once you try to turn a corner. Certainly they are correct as far as they go, but the kinematic and dynamic effects are missing.
     Take the last drawing, where rudder offset is balanced with the leadouts. I think we all generally agree that you have to have that, regardless of what yaw angle you want to run. If you have rudder offset, you have to move the leadouts back to compensate or you end up with wild line whip reactions when you start to maneuver.
      To turn without incurring any sort of disturbance, the airplane has to rotate around the vector Fc (the radial vector, from the pilot to the CG). The problem is, unless you do something to force it, *it can't and won't rotate around that axis* because they aren't the principle axes. Barring other inputs, it wants to rotate around the Y axis of the airplane, and that isn't aligned with the radial vector. If the airplane rotates around its own Y axis by 90 degrees, it winds up vertical with a large roll angle, effectively appearing to have inadequate tip weight. The usual solution is to add tip weight to keep it from hinging. But the effect of tip weight varies depending on the pitch acceleration, so you can't have it balance at all rotation rates (including zero). This leads to what I previously called "Twister Disease". No one appears to have been able to resolve this satisfactorily that I have seen over *many* examples.
    A possible solution would be to skew the principle axes with respect to the airplane, so the momental Y axis lines up with the radial vector at whatever yaw angle you want to run. You can skew the principle axes around the yaw axis by adding mass at the inboard tip TE and the outboard tip LE, and it has certainly been done. The problem is that to get any consequential shift, you have to use a lot of mass and effectively that means you can only make small adjustments rather than wholesale changes. And, in any case, if you were to successfully get the principle axes shifted around, now you get huge aerodynamic torques because, for example,  the lift from the tail is centered in the wrong place, there's a huge dihedral effect,  and a host of other issues.
   The alternative is to create some torques that oppose all this. I can easily believe that the moving rudder can compensate for a torque that appears as a function of the pitch rate as was intended. Precession is certainly that way, but the kinematic effect is completely independent of the rate and cannot be corrected by moving the rudder in the direction of the elevator. You might be able to move the leadouts off the natural "trail" position and use the dihedral coupling roll and yaw to induce a yaw angle that then rolls the airplane as required, but that also requires that you put force on the lines that almost guarantees that the line whip will get excited.
     This was all hashed out long before in various SSW posts. The method I recommend for adjusting the rudder and leadouts will align the geometric axes of the airplane to that Y lines up with the radial vector and remove most of the roll.yaw dihedral effects.  Building the airplane with matched parts from side to side will get the inertial Y axis lined up pretty close to the geometric Y axis. I think it's close enough that small dynamic balance effects and precession are both in the negligible range most of the time, or at least close enough that other effects like details of workmanship will swamp the effect. If you have enough passive yaw stability and don't use excessively large props, and don't build too light (which increases the line tension stabilizing forces without exacerbating the other issues),  it's below the threshold of caring about it.
      I have seen next to no one able to trim with a significant static yaw angle successfully. The few exceptions are those case (like the Firecracker) where there is very little passive yaw stability so that slewing around in yaw doesn't encounter any significant impediment - not that it doesn't yaw, it just doesn't care. Otherwise you get wild fishtailing in the maneuvers. The worst example I have ever seen in an otherwise competently constructed airplane was a 54-ounce, PA65 airplane with a 3-blade Bolly 13-4 or so and a very large fin with lots of offset.
     big fin = lots of passive yaw stability/authority
     offset fin  = lots of aerodynamic yaw torque
     huge very heavy prop = lots of precession and other aerodynamic destabilizing force
     abnormally light weight = reduced stability provided by the lines and in conjunction with very heavy .018 lines, huge influence of line whip effects
   This airplane was in an almost continual pretty high frequency roll/yaw oscillation that only damped out in the two laps between maneuvers in perfect air. Anything else, and it got upset, and stayed upset with very light damping. It would make about 3 swings in the space of one leg of a square loop, for example.
Offline Igor Burger
« Reply #74 on: November 05, 2016, 04:59:00 PM »
Brett, I would say you have too pessimistic approach to the point. I think it is better to go from opposite side, we can simply presume it DOES make clean turn (because I see it clean, no ill yaws, rolls etc). So now questions is how it is possible.
There 2 independent problems:
1/ Permanently yawed model has misaligned aerodynamic center (AC) of tail and AC of wing like you wrote. That configuration will clearly need tip weight to solve the rolling problem. And it is also clear that that tip weight will need to be different in tight turn and different in large radius and level flight. So far all my models needed LESS tip weight in tight turn and more in loops. It is very clearly visible in overdone (too tight) corners when outer wing rolls out. My solution for that problem is trim tab on right flap. Its size has smaller percentual effect in small deflection and stronger at large deflections - just because of flap to wing ratio. Well, it is not "mine" solution, it is known trick to use larger flap on righ wing, mine is only variable size for efective trimming. So far I always solved that problem to extend that even in tightest corner I did not see any roll and model has still plenty of line tension for example in eight overhead in wind when the wind tends to roll model inwards.
2/ There is also another, not so obviouse problem which you did not mention, it is fact that yawed model is not dynamically balanced. Every wing (left and right) has its CG, left wing has CG front of main GC and right wing aft of CG. If model rotates, centrifugal force will tend to force them out of rotating axle, means to yaw the model out. We have also fuselage, front of fuselage has CG right of the model CG and tail has CG left of the model CG. So it will tend it yaw in. But since fuselage has heavy battery balanced by long tail, it has likely stronger effect compared to wing, so model will tend yaw in in both positive and also negative turns. Looks like we need rudder which deflects right in every turn to keep constant yaw. We have also precession which is the same (in absolute value) in positive and negative turns, but with opposite direction - means we need rudder in in positive and the same amount out in negative turns. So if I sum both effects, I will need little more rudder out in negative turns and less in on positive. That probably answers why I need 20 deg out and only 15 deg in.
Yes I agree, it looks complicated, but we know and we use those 2 tricks for years and both work. May be not everyone can set it for 100%, but small roll or yaw is still better than if model yaws in during flight overhead - and thanks to that yaw still makes mentioned problems :- )))
And I do not think my model is trimmed different way than your, I bet your model also flies yawed, and I bet it is also trimmed the same way, just much less yawed then mine :- ))
« Reply #75 on: November 05, 2016, 06:14:01 PM »
All right.  I think everybody on Stunthangar should throw in a couple of C-notes to buy Igor a ticket to fly to San Francisco with his airplane. We can arrange accommodations at the David Fitz'  Bed and Breakfast and then hold the Igor/Brett airplane swap showdown at David's OK Corral--oops--Napa flying site (we can all go wine tasting afterward...or maybe Igor and Brett should go before flying to impart a touch of daring-do to the event).  We'll give each guy six flights on the other guy's ship and then hold a contest with a couple hundred of Sparky's closest stunt buddies all judging to determine...I'm not sure what...  Never mind, they'll both fib and say they're more convinced than ever that their own is clearly superior and we'll have solved no secrets whatsoever.
Frankly, after reading all of their back and forth I'm afraid to fly my own stuff lest they prove themselves un-airworthy...I'm too old to build any replacements.
Ted
« Reply #76 on: November 05, 2016, 10:12:40 PM »
<<snip>>
       I did mention that, it's the same as the dynamic imbalance/product of inertia issue.
  The reason it moves outboard more than inboard is that moving it outboard increases the line tension (over what it would have had otherwise) so the restoring force from the leadouts is greater. Move it inboard and it removes line tension, meaning you can tolerate less of it because the restoring force is reduced. Same with the original Rabe rudder (which was intended to solve a different problem).
   Maybe. I can bound the maximum static yaw angle to less than 1/4 degree since the 1/8" inboard landing gear hides the outboard landing gear in dead air with no other disturbances.
   I understand what you are trying to do, the explanation from 2004 was clear enough.  If you fly with a static yaw angle it creates a bunch of axial coupling from a variety of effects (products of inertia, aerodynamic, etc), and you are using the rudder and tipweight adjustments, and a movable rudder to create torque to counteract them.
   All I am saying is that of the hundreds and hundreds of people who have tried this, I haven't seen anyone one of them manage it particularly well, and they ended up flying hundreds of flights a month to try to work around it by trying harder.
    I can see that now I am going to have to start carrying my Zona saw around to cut people's rudders to remove the offset, when everybody gets the great idea to try to fly sideways again.
  I don't claim anything with regard to understanding the forward CG or aft leadouts for electric (or 4-stroke) and I am more-or-less taking Paul's word for it. Even though my engine can be set to run on either side of any electric system (more steady than a feed-back electric system and more punchy than a governor system). His airplane doesn't appear to fly yawed out, at least not that I can tell.
« Reply #77 on: November 05, 2016, 10:37:15 PM »
Ted
AAwwwww, Ted....You can't bring common sense into a discussion like this!  Especially since it's reasonable given past contest results, to assume, that both or either approach can work.
One thing that I do wonder about is that it seems that this entire discussion ignores the action of the flyer and his handle movement to follow, lead, or trail the aircraft.  My opinion is that this is a very important part of what actually happens regarding line tension and yaw or lack thereof!  Probably very difficult to factor that into the diagrams but I believe it is a very real input and likely the primary reason for different reaction to different setups!
No...somebody prove me wrong.  It really seems to be the only thing that explains the "WHY".  I don't think any of the top fliers do so with the handle in a static position as the diagrams or equations always seem to show.  I believe it's actually a much more complicated dynamic situation, than described by anything so far!
Simple body, handle "English" to overcome forces that seemingly cannot be statically or dynamically balanced by straight forward trim methods because they are constantly changed by influencing dynamic and aerodynamic forces that do not balance.
« Reply #78 on: November 06, 2016, 01:57:09 AM »
Curiously enough, Igor goes to Silicon Gulch to visit his kid.  Last time he went, he hand-delivered some stuff to Jimby.
« Reply #79 on: November 06, 2016, 01:04:40 AM »
That's an interesting thought.  I find myself doing peculiar hand jive, like on the last corner of triangles.  When that happens, I figure I'm compensating for some mistrim, but I'll watch the Varsity more carefully.
Offline Igor Burger
« Reply #80 on: November 06, 2016, 08:25:18 AM »
:- ))) ... I was twice here this year. Once in February (and that is one of reasons why I traveled to Perth with 2 weeks old model and I trimmed it there every evening :-P ) and second time in August, but I must say that there is lot of other fun than flying models :- ))
Offline Igor Burger
« Reply #81 on: November 06, 2016, 08:32:50 AM »
That is right only in case that rudder does not solve all movements, if you again try that "optimistic" approach, that rudder keeps in turns that orriginal static yaw and model does not hinge right left in turns, then gyro moment, which is on both sides the same in absolute value, will need also +/- the same moment of rudder and thus +/- the same deflection :- )) Yes yes, I know it brings another problems, but they are also solvable :- ))
« Reply #82 on: November 06, 2016, 01:39:00 PM »
     I hear you learned something important about Bay Area traffic around 5 in the afternoon, too! Specifically, don't plan on getting anywhere in any reasonable amount of time.
« Reply #83 on: November 06, 2016, 01:50:35 PM »
   There are no secrets. The kinematic effect described above, for example,  *is not a matter of opinion* and has been mathematically perfectly well-understood since the early 1800's. I think Igor and I understand what he is attempting pretty well, since it's a technical matter that us not subject to debate. The only opinion involved is how well you can resolve the well-understood static/dynamic/kinematic using the available trim features. Having seen many people try to do what he is doing, I am skeptical, but...
       after all this time of both helping other people trim, evaluating their airplanes, and advising them, I think I am capable of making my points without fabricating data or failing to be objective about the results.
  I gave my opinion on how to proceed for the original posited problem about 30 responses ago. No one has to follow it. If the rest of it is of no interest or a pointless debate, no one is compelled to read it. People have done this by-guess-by-golly trial and error with some success for 60+ years, no one is required to understand it to brute-force their way to a solution.
« Reply #84 on: November 09, 2016, 11:12:36 PM »
A big thanks goes out to Howard for actually giving some dimensions for both CG shift and LO changes between IC and e'ons. Unlike previous posts. I appreciate it. We all should.  H^^  D>K Steve
« Reply #85 on: November 10, 2016, 01:58:16 PM »
Well...
Dimensions are pragmatically valuable but do nothing to help lay people understand the physics involved which is of more interest to me.  I can measure the difference between the CG vice leadout rake trim on Brett's plane versus Igor's/Paul's/Howard's/ Orestes'/Jimby's, et all; I just don't understand why the difference is so great nor why it is so much different from otherwise nominally similar stunt ships????
« Reply #86 on: November 10, 2016, 03:56:44 PM »
    After 15 days I still do not see anywhere where it tells us if this is occurring during level flight with no control input or is this seen during a control input. If it is during control input then it is a easy problem to find.
 If I missed this point somewhere forgive my oversight.  HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~>
« Reply #87 on: November 10, 2016, 04:55:07 PM »
... I just don't understand why the difference is so great nor why it is so much different from otherwise nominally similar stunt ships????
Me neither, but here are my bizarre hypotheses:
1. Dynamics:  This I think generalizes what Brett said above.  For a stunt plane to make a nice corner, it must start rotating about a given axis, then keep rotating about that axis, then stop rotating, all without any tendency to rotate about another axis.   This requires the vector sum of moments on the airplane to be in the same direction as the rotation throughout the maneuver.  One of the component moments is due to rotating the airplane about an axis that's not a principal axis, and that's a component we can vary by adjusting the leadout position.  Dynamic differences between our electric and acoustic Impacts include:
a) the magnitude (which I haven't calculated) of the moment due to precessing the rotating machinery,
b) the moment due to deflecting air through a prop offset 2 degrees from the airplane body axis,
c) all moments due to the time histories of RPM,
and d) a difference in the direction of principal axes due to different mass distribution.
Moving the leadouts might be changing the axis about which the airplane rotates, thus changing the off-principal-axis moment component and also some aerodynamic moment components.
2. Statics: Maybe the line drag is way different between electric and acoustic airplanes.
« Reply #88 on: November 10, 2016, 11:45:07 PM »
Well...
No, but it's a start, unlike those others. Can't measure what we don't have access to. Not that I ever measured the CG shift of any of my IC planes.
Maybe it's all about the vibration of IC's and induced circular motion of the flying lines changing the drag of the lines, vs. no vibration and a different drag factor. Increased, I 'spect. Increased drag would align with the LineIII etc., where bigger lines or higher speed shifts the LO's aft. No, I don't see why a flying line whipping around like a jump rope would cause less drag than one being nicely behaved. I think that's what Howard mentions in item 2.0 above, but I wouldn't swear to it.  LL~ Steve
Offline Igor Burger
« Reply #89 on: November 11, 2016, 12:47:48 AM »
Just for record:
This plane which I built for WCh 2002 had CG at 15% with empty tank. (however it was small tank aproximately 160ccm )
http://www.netax.sk/hexoft/stunt/the_max_ii.htm
The xtreme forward CG position was due to its new logarithmic unit on flaps.
It is the same plane which I flew 2008 reworker to electric in 2008 and I fly it as B model till last year and still hanging on wall, so I can measure CG position. It is at 20% now - with battery installed (charged to half  >:D )
And I do not remember that I shifted CG dramatically, I think it was just slow progress in time. ... moments are very similar, light motor/engine and heavier tank, the same lines, 2 blade 12" props on both (now I fly 3 blade NOT hollowed)
So may be question for Paur and Howard - are you speaking about the same but reworked model, or you mean 2 different models? (sorry if I missed answer in text before) And if not, are controlls, area, etc... the same?
« Reply #90 on: November 11, 2016, 11:44:34 AM »
I fly an IMpact that is electrified, it exhibits the same characteristics mentioned,, the CG is forward over an inch from the plans location of the glow impact. THe leadouts are WAY back, not quite as far as Paul has his, but then my model is 7 ounces heavier and flies a touch faster so that matters.
Steve, I have told you several times that the cg is farther forward than a glow model WITH a full tank.
I am not sure Igor's findings apply directly because his trim is different vis a vis the Rabe rudder and other trim. But I know Pauls setup, I know my airplane the closer I got it to Pauls setup the better it flew..
I would love to know the why but for now I am equally happy with just having the performance without the why.
Offline Fred Underwood
« Reply #91 on: November 11, 2016, 12:01:24 PM »
What will happen on the Max Bee with a fixed rudder?
Fred
352575
« Reply #92 on: November 11, 2016, 04:30:10 PM »
...or higher speed shifts the LO's aft.
Both the sideways acceleration on the airplane and the line drag increase with the square of speed, so speed doesn't matter much for leadout position, except for: a) part of the wind, and b) a puny Reynolds number effect.
Mark, I notice that you tend to be a little slow in releasing the shift key, which could cause it to burn out prematurely.  Hope this helps.
« Reply #93 on: November 11, 2016, 05:07:48 PM »
Howard, ok point taken about the speed effect, however would not the weight be an issue?
as to the shift key, mine gets neglected regularly so I try to give it a work out occasionaly to keep it in sync with the remainder of the keys,,,,,
However part of the problem is my recent replies to vairous political fear based posts which have caused me to be a bit more pronounced with my shift key usage, perhaps its a carry over?
out of curiousity, does your more robust Impact tend to have the leadouts in the same place as Pauls less robust versions?
