I flew a primary force for a while. I built mine from Mike's plans and one of the first laser kits he made, but it should be pretty much the same plane.
I flew mine on an FP 25, LA 25, and an OS26 4s car motor on a tiny aluminum pipe with a tiny prop at an insanely high RPM. It worked but FP was the best option.
I flew on APCs of the 10" variety and the flattest pitch I could find. IIRC I think I had a 3 pitch. Making sure to run the engine in a mildly rich 2s on the ground with only a minor burp here and there in level flight throughout the pattern. No 2-4 stuff here. I ran Omega RC 10% nitro fuel and the FP LOVED IT!! My FP 40 ran its best on that stuff too. No, it's not stunt fuel but then again we aren't talking about a stunt engine either. Can't remember the RPMs off hand but it was well over 10K at launch. I wanted the RPMS as high as possible with the smaller motor keeping the engine in its designed power range. I don't know off hand the timing of the evo 36 but if they are near what their RC counter parts are then you would want the recommended fuel to get the most consistent run. Horizon says the operating range for the evo 36 is 9300 to 17000. You are just barely touching the operating range at take off. This may lead to what I describe below about speeding up.
Things to try...
Take a lap time right before the RWO. Then take it again after the round 8, and again after the clover. You are describing a situation where it is just too rich for the over head pass in the winds, especially if you miss the wind. The motor is still kind of cool at this point and has had no load placed on it yet. It's probably still breaking and sounding normal but it is still a tad rich. The lap times throughout will tell you right away if this is your issue. It may not feel that way on the handle as the flight progresses because the performance increases with speed/power and you are able to properly fly the plane. If you are getting a large speed up by the end of the tank, more than .03 tenths. You will want to look at how you have the tank plumbed or shimmed and see if you can get it down to .01-.02 speed up by the end of the flight.
I would also recommend taking the lines down to 60' i-i. This was the max length I could get before the model would start faulter. In your case you will go down on lap time to around 5 seconds but that wont be bad at that length. it would actually be pretty good especially if the lap times are consistant beginning to end. The increased speed will pull it through the RWO that much better.
I would recommend staying with the flattest APCs you can find, even if you have to go down in diameter, get the RPMs up, way up! With that restrictive muffler you can mimic a piped system with high RPMs and flat pitches. Run it 2-2 and you can hear the soundwave rattle on the ground before launch. It' works really good once you get it the right range.
