  • July 11, 2025, 08:54:39 PM
Author Topic: Trim Questions.. with warped elev..  (Read 1157 times)
« on: March 05, 2016, 01:35:25 PM »
I have an old stunter that has a warped Elev..  If the left side's outboard is o.k. at neutral position (view from front)   but inboard portion has about 2-3 degrees up.. do you line up more with the outboard or the inboard with the right?  basically which way is more critical.
Thanks in advance
Offline Phil Krankowski
Re: Trim Questions.. with warped elev..
« Reply #1 on: March 05, 2016, 02:20:40 PM »
Can the elevator be fixed?  Wood can be warped with heat very easily and brought back to alignment.  (an iron, steam, or boiling water) and metal parts can be bent carefully.
Phil
Offline Paul Walker
« Reply #2 on: March 05, 2016, 02:38:55 PM »
Don't try to fly it with something warped. Heat or cut it to get it straight.
If the elevator is that warped, what about the rest of the plane?
« Reply #3 on: March 05, 2016, 03:26:31 PM »
If the warp is even then split the difference but if only a smaller part is warped then line up on the straight side. I have a plane with a warped elevator. I could fix it but it flys so darn good I hate to mess with it.
« Reply #4 on: March 05, 2016, 03:29:29 PM »
Fix it!  Then get back to us.
« Reply #5 on: March 05, 2016, 03:30:46 PM »
Phil
It is paint finish, and I have tried steam & heat before.  but it always springs back about a day or so.
As far as I know the rest of the plane seems o.k,   I know it's best to fix it or replace it.  I'm just wondering if I had to fly it as is..  would aligning it a certain way help?
« Last Edit: March 05, 2016, 06:08:02 PM by Joe Yau »
« Reply #6 on: March 05, 2016, 03:35:00 PM »
I have a plane like that as well.. and that's exactly what I did. and it flew o.k.  but this one has tracking issues.
« Reply #7 on: March 05, 2016, 03:46:50 PM »
Try steam & heat, and then fixture it so that it's bent slightly against the warp and leave it there for a week.  Then see if it holds.  I've done this with profile fuselages with success.
I've also had success using heat & whatnot to bend something well beyond the original warp -- it relaxes back in the original direction, and if I'm lucky it goes where it belongs.
Offline TigreST
  • TigreST
« Reply #8 on: March 05, 2016, 04:03:19 PM »
What is the airplane name/type in question?  Knowing the design may help one come to a repair/replacement plan for the elevator.
Tony Bagley
Ontario, Canada
