Hello Brent,
When hunting down problems like this always start with the easy stuff first.
You have told us it s flying upright and inverted level. That's good. We are to assume the model is straight. I am assuming is a proven design as well.
Your statement about more power has me wondering. Do you mean more speed or more power? Speed will always mask a problem until too much creates its own. There is a happy medium in there for every setup.
Do you have a fixed rudder with offset built in? This is really key when it comes to proper LO setting from the get go. I fly with an airfoil sanded into the rudder and find I use a further forward LO setting than models where I used an almost straight rudder. These little things are good to know when making an initial setup.
So looking at option 4 on the Walker Trim Flow Chart, you need to adjust leadout, rudder, TW, and engine offset if you can. Where to start is the next question right?
I would move the lead outs forward maybe 1/4" and fly 2 times and note what you get. If the conditions worsen the exact same symptoms then you know you went the wrong way. If the condition seems a little better but not quite there add some TW and fly two times and see what you get. If it continued to get better as you added TW then move the LOs forward again and fly. If better still then add more TW and fly again. I say fly two times so you can really see what the changes are. If it is a drastic change right away then there is no need for the second flight. Just change and move on.
It could be that the inside turn is causing too much yaw and you lose tension. By moving the LOs foward you pull the nose in and fight this natural yawing condition that you have on the inside moves. The outside yaws the opposite direction. It is common to start or trim a plane initially with the LOs to far back. It's the natural instinct to move the LOs back and "point the plane away from you" but in some cases it makes the maneuvering worse.
The WTFC (Walker Trim Flow Chart) is an awesome tool. Thank you Paul for putting it out there for all to us to use. I used to have one in my flight box all the time. Then I spilled fuel on it and well it was ruined.
It really helps you look for issues in the right order and then find the proper compromise for the model. Works on ALL adjustable stunt panes.
I like to think of trimming as "Sneaking up on it." Then all of sudden "BOOM" it all just works.
Keep us posted.
