General control line discussion => Open Forum => Topic started by: Brad Smith on January 11, 2012, 01:43:45 PM
Title: TRI STREAK 45
Post by: Brad Smith on January 11, 2012, 01:43:45 PM
I was going thru some papers and found something about a TRI STREAK 45, anybody heard of this if i so, im looking for the plans thanks.
Title: Re: TRI STREAK 45
Post by: Clint Ormosen on January 11, 2012, 09:02:21 PM
I haven't heard of either, but it sounds interesting. Does it use 3 engines?
Post by: wwwarbird on January 11, 2012, 09:04:41 PM
 New one on me too. A 'Streak with three .15's??? VD~
Post by: Brad Smith on January 11, 2012, 09:06:40 PM
No its tri wing plane useign the flight streak wing.
Post by: wwwarbird on January 11, 2012, 09:08:38 PM
 Whoah. Sounds like a kite. ;D
Post by: Clint Ormosen on January 11, 2012, 10:20:12 PM
oh. that's not as much fun. *sigh*
Post by: john e. holliday on January 12, 2012, 05:53:00 AM
Somewhere in the shop I have plans for the Bipe Streak, yes a biplane.   It was built and flown.  Not a pattern airplane, but was a great sport plane.   After several dozen flights the top wing decided to go another direction because of the speed I was flying at.  Did not rebuild it.  I think the person did have a Tri Streak in development. H^^
Post by: Brad Smith on January 12, 2012, 06:56:07 AM
Hey John do you still have the plans maybe there is name on there. Or do you know who made the bi streak plans.
Post by: Brad Smith on January 12, 2012, 08:16:15 AM
here is the plans i have not much to work with.
Post by: john e. holliday on January 12, 2012, 08:48:55 AM
Did not have to go to the shop.  Did a search on the Bipe Streak and the culprit(designer) is our own Pat King, that has a list of plans on the Brotherhood of the Ring site.   Did not see it listed tho.
Post by: Bill Little on January 12, 2012, 08:57:22 AM
Hi Doc, (and all)
I would say it is Pat King who did the Tripe Streak.  Pat does not have some of the older designs of his listed in the Vendor's corner, but a PM or email will get the info.
BIG Bear
RNMM/AMM
Post by: rustler on January 12, 2012, 02:27:13 PM
Clint - Why wait for someone else? You could produce the first 3-engine Streak!
Post by: pat king on January 13, 2012, 11:36:53 AM
Brad,
I checked, I have not had any Tri Streak 45 kits cut. Send me a message to:patdk@aol.com and I'll send you full size .pdf files of the plans.
I do have a Streak 45 kit (52" span 622 square inches) in stock.
Thanks, Pat H^^
