  • July 17, 2025, 11:58:08 PM
Author Topic: Torpedo Special  (Read 4482 times)
Offline Dalton Hammett
Torpedo Special
« on: September 24, 2010, 12:33:54 PM »
After reading the thread on the Sportsman .29 I got motivated to dig a bit in my old engine barrel .  I have two old engines marked Torpedo Special I am going to clean up.  They look a bit like the old K&B torps except they have a double stack kind of angled back and the front shaft looks like they might have been originally designed for ignation but these are both set up with glow plugs.  I was wondering if anyone of the engine experts here might know a bit more about them.  They appear to be about a .29 in size.
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Re: Torpedo Special
« Reply #1 on: September 24, 2010, 12:53:19 PM »
Offline tom hampshire
Re: Torpedo Special
« Reply #2 on: September 24, 2010, 01:32:04 PM »
Hi Dalton - It was marketed as a 'Torpedo", but not by K&B.  It was built by Miniature Motors of NYC.  Low nitro and low RPM if you run it - the crankshaft is weak.  Tom Hampshire
Offline W.D. Roland
Re: Torpedo Special
« Reply #3 on: September 24, 2010, 01:49:12 PM »
Hi Dalton
Was going to post what Tom posted
I believe that is the case with your engine based on description with out visual aid.
Use a lot of oil, guessing 30+ % castor.
Tom, thanks for adding to my Ed with the crank info.
David Roland
51336
Offline Jim Oliver
Re: Torpedo Special
« Reply #4 on: September 24, 2010, 02:01:22 PM »
Maybe it shoulda been marked "Torpedoed"....... VD~ ;D
Jim Oliver
AMA 18475
Re: Torpedo Special
« Reply #5 on: September 24, 2010, 02:07:46 PM »
Running glow is a lot harder on engines than ignition with gasoline.  One of the reasons that there was a shakeout in the engine manufacturer's after WW II was because a lot of gas engines couldn't survive glow operation, and resources (and probably knowledge) for redesign were hard to come by.
Re: Torpedo Special
« Reply #6 on: September 24, 2010, 02:42:54 PM »
Thanks a lot guys for the information.  The engines are not the one pictured in Tim's first link but could be the one from Mineature Motors of NYC.  One of the two is pretty worn out but the other still has good compression.  I will try to take a picture of it tonight and update here tomorrow.  Thanks again....
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline Bill Gruby
Re: Torpedo Special
« Reply #7 on: September 24, 2010, 05:20:56 PM »
 Pix, bottom center #2 Info top right.
 "Billy G"   <=
Bill Gruby
AMA 94433
MECA 5393-10
Re: Torpedo Special
« Reply #8 on: September 24, 2010, 05:52:27 PM »
Dalton,
If you ever become interested with parting with one or both of these, I'd be interested at the right price.
Offline Garf
    • Hangar Flying
Re: Torpedo Special
« Reply #9 on: September 24, 2010, 07:56:28 PM »
This one? They made 2 models. One steel fin, one sleeved.
Offline Bill Gruby
Re: Torpedo Special
« Reply #10 on: September 24, 2010, 09:09:28 PM »
 Steel was 1946 -- 1949 had shrunk on Aluminum Fins and the case was not machined for a Timer.
  "Billy G"  y1
Bill Gruby
AMA 94433
MECA 5393-10
Re: Torpedo Special
« Reply #11 on: September 25, 2010, 06:46:59 AM »
OK, Bill and Garf have found it.......
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Re: Torpedo Special
« Reply #12 on: September 25, 2010, 06:48:01 AM »
From the front
DH
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline david beazley
Re: Torpedo Special
« Reply #13 on: September 27, 2010, 09:37:31 AM »
Dalton,
Let us know how it runs.  I have one that I have been thinking about running.
AMA # 2817
Offline Bill Gruby
Re: Torpedo Special
« Reply #14 on: September 27, 2010, 01:59:35 PM »
 The pix was fuzzy but it looks like the fins are shrunk on. That would make it a 1949. The only way to really tell is to remove the head. If the sleeve and fins are one piece it is a "Steel 1946" If two pieces it is a 1949.
  "Billy G"  H^^
Bill Gruby
AMA 94433
MECA 5393-10
