  • June 23, 2025, 01:19:49 AM
Author Topic: Fun51 Build  (Read 1019 times)
Offline Phil Coopy
Fun51 Build
« on: August 27, 2007, 09:18:37 AM »
If I build a Fun51 for stunt, are there any modifications that those of you who have built them, would make to the original dimentions and structure?
Phil
Offline Leester
Re: Fun51 Build
« Reply #1 on: August 27, 2007, 11:15:34 AM »
The kits motor mount system needs help, there's is layers of plywood, real maple mounts should be used. Other than that just convert to c/l, adj lead outs, tip box the normal stuff. Mine has lasted 3 yrs. just flew it yesterday, is a great goof off plane and cheap, Tower has the kit now for 39.99. There are plenty more mods you CAN make but can live without unless you want them.
Good Luck & Have Fun.
Leester
ama 830538
