Use care with the Power Dissolve cleaning an engine that is not apart, it will rust and corrode the steel screws, steel spraybar needles etc. I f you use it take the steel parts out, or remove the screws and all steel parts after you clean ,Then clean the steel parts ,neutralize and oil very well and then re-install the the screws and other steel parts.
Also If you have a steel sleeve you will not like what the lip and many times the inside will look like if you do not clean thoroughly and re-oil after using the cleaner
Also pay heed to Paul's advice about keeping the antifreeze away from animals
