At least one more from me.
You are flying by yourself and using a stooge. This stooge is a simple device with no spring loaded release mechanism. The release, supposedly, happens when you pull on a string and it pulls a pin out of a loop in the tail wheel strut. So, start the engine, set the needle and start walking to the handle with the lines in your left had to make sure you have the lines untwisted, the engine is running satisfactorily, all is going well until about 1/3 of the way to the handle, then you hear behind you a sudden acceleration as the engine unloads and the lines in your left hand have an uncomfortable feel to them. Then you realize that the airplane has taken off and the lines will soon be and then are wrapping around you.
I could go on and complete this story, but it is almost too unbelievable. To make the story short, a recovery was made with no damage to the model. The lines were a total loss.
