  • July 22, 2025, 12:01:31 AM
Author Topic: Too much pull/line tension, how to fix???  (Read 2589 times)
Offline Matt Colan
« on: August 02, 2009, 10:58:11 AM »
Grandpa has a P-40 that weighs 65 ounces, and is powered by an ST 60 swinging a 13-6 bolly prop.  What he keeps on complaining about is that the plane pulls like a bear.  The leadouts appear to be fine, and he took a little bit of tip weight out, because I saw it was hinging a little bit.  He did have 1.9 ounces of tip weight, and now has 1.4 ounces in it.  I've flown the plane and it does pull a lot, but I don't think it pulls enough to the point that he is complaining so much about.
He has the plane flying on 68 and a half foot lines, from the handle to the center of the plane, so the plane is pretty well out there.  Is there any way he can get rid of some line tension and pull.  He just finds the plane very unenjoyable because it pulls the plane so much.
Offline Brian Massey
    • California Car Clubs
Re: Too much pull/line tension, how to fix???
« Reply #1 on: August 02, 2009, 11:22:39 AM »
Several questions; First, what kind of lap speeds? Can you slow the plane down and keep the line tension that you need. Also, if the engine as some offset, maybe you can take it out, or if there is rudder offset.
I'm sure others have better thoughts, but this is what I would check first.
Brian
AMA 55421
Madera, CA
Offline Matt Colan
« Reply #2 on: August 02, 2009, 11:36:42 AM »
There is no engine offset, and grandpa doesn't want to fool with it.  There is a very little rudder offset.  The plane I think is flying around 5.3 lap times, and he can't really fly it much slower, because it starts to lose line tension up top.  The motor on a good engine run, is in a deep growl 4 cycle in level flight, and when the plane pulls up into a wingover, towards the top it goes into a two cycle, and then on the way back down it goes back into the growl.  On the ground, the prop is tached at 8600RPM.
Grandpa also has Vic Macaluso's F-14 from the Flying Models article back in 1997.  That plane is powered by a PA 40 pipe and weighs 70ish ounces.  I haven't flown it, but he says that the F-14 pulls less than the P-40.  The lines on both planes are a similar length.  That I found suprising when he told me that.
Alan Hahn
« Reply #3 on: August 02, 2009, 11:53:08 AM »
Well the standard thing is to move the leadouts forward a bit (I know you mentioned that they are fine as is--at least trim-wise). This should lower the tension on the straight and level, but keep it ok up at the top.
Also give Grandpa a break! I bet his poor old shoulders have a lot harder time than yours! :)
« Reply #4 on: August 02, 2009, 12:12:06 PM »
What sort of prop on the ST .60? A baseline ST .60  prop is a 12-6, but some run up to 14-5's. I'd just about guarantee that a stock (balanced) Zinger will reduce the line tension...maybe too much. I think more diameter would make more line tension, and less diameter would reduce it, as a very general rule. However, even the same brand prop can give totally weird results, so you can't really predict anything. Just try stuff!
I would suggest getting rid of the rudder offset, trying different props and moving the LO's around. By removing the rudder offset, you might find the LO's need to go back a bit, but they might be ok as-is. If it loses tracking, move the LO's back. Refer to PW's trimming flowchart and Brett's article about what does what!  I attached both, with Brett's article being both copy/pasted & attached as a .txt file. Print 'em out and take both to the field.  y1 Steve
"Functions of trim adjustments....By Brett Buck
The trim of the model is by far the single most important factor (aside from the quality of the engine run) in making the airplane fly well. To fully trim the airplane, people have added more and more adjustable trim features. Everybody know that you are supposed to include all the modern adjustable features in the your killer stunt ship. But it’s often asked what they all do!
Without attempting to cover how to trim a stunt plane (a topic upon which we could easily get to Encyclopedia Britannica dimensions), it’s at least worthwhile to know what nominal effects each trim adjustment had. I say “nominal” because one of the most important factors to learn in trimming and even designing airplanes is that a change in one area almost always affects everything else. There are a few examples below, but these are just the tip of a huge iceberg, and the descriptions, while hopefully useful, are an oversimplification.
I have divided the adjustments into those that primarily affect the Roll and Yaw axes, and those that effect Pitch. For those who haven’t been studying aeronautics since their pre-natal days, these terms may be unfamiliar or at least not well-defined, so I’ll take a stab at it.
The pitch axis of the airplane is the one you control - nose up and down. Positive pitch is nose up. Roll is rotation around the “long” axis of the airplane from the nose to the tail. A positive roll tilts the airplane to the right, so that, for example, in level flight, the right wing is down and the left wing is up. Yaw is a rotation around the “vertical” axis of the airplane, nose to the left or right. A positive yaw is a rotation to the right, so that the nose is aimed to the right of where you are going.
Note that these are all relative to the airplane. Right/Left/Up/Down are all determined as if you were in the pilot’s position - not, importantly, relative to the ground, unless you happen to be flying level. That’s important to remember, and I have seen many, many situations where people became confused about it.
Also, given that they are angles, it begs the question “angles relative to what”. That’s an interesting question, that would take some time to think through and explain, but for the time being let’s say that roll and yaw are relative to the line drawn from the airplane to the pilot. So, there you are, flying happily through the maneuvers. At any instant, you could imagine a line drawn from your hand to the center of gravity of the airplane. In level flight it would be parallel to the ground. In the intersection of the overhead 8, it would be perpendicular to the ground. The roll angle is the angle between this line and the “side-to-side” axis of the airplane, and the yaw angle is the angle between this line and the “long” fore-and-aft axis of the airplane. And let’s say that the pitch angle is the angle of the long axis of the airplane relative to the current direction of flight. They aren’t the same! The nose can be pitched up or down relative to where you are actually going.  This is not an entirely satisfactory definition, but it will do for now.
I will also emphasize that virtually none of the information in this article was invented, discovered, or first explained by me. It’s an accumulation of the knowledge of others, and I don’t even know where I first heard of some or most of it. So I can’t provide attributions properly. I apologize in advance. There’s no intent to claim it as my own.
With the preamble and caveats out of the way, on to the adjustments.
Roll/Yaw adjustments
Tip weight: primarily affects the ROLL axis More tip weight than necessary rolls airplane away from you, which, VERY APPROXIMATELY directs the lift vector away from you, and gives you more line tension. Too much and it pulls hard, but the line tension varies a lot, too, and the airplane oscillates in roll (hinging). Adjust to keep roll angle at zero through maneuvers.
Rudder offset (fixed/ground adjustable): primarily affects the YAW axis, although yaw and roll are very strongly coupled. Set the *equilibrium* yaw angle, or the yaw angle at which the airplane flies in steady level flight. In my opinion, the goal is to set the equilibrium yaw angle to zero.
Rudder offset (in-flight variable - "Rabe Rudder"): pitching the airplane while having a big prop up front, spinning at goodly RPM, causes the airplane to want to yaw "nose-out" on inside maneuvers, and "nose-in" on outside maneuvers. This cannot be fully corrected by a fixed/adjustable rudder. So Al Rabe figured out to hook the rudder to the elevator, so it moves to give more left rudder on insides, and more right rudder on outsides. Usually, it needs to be asymmetrical, moving a lot more right than left (for reasons that might or might not be obvious).
Note that the purpose is most emphatically NOT to make the airplane yaw nose-in or nose-out, in fact it’s to prevent the nose from yawing in or out by providing a compensation that counteracts the precessional torques.
If you adjust it right, it compensates well for the precessional effects. Al’s worked well. Problem seems to be that unless you are an absolute expert-level trimmer you will not get it adjusted correctly and, given that it's a very powerful feature, it is almost always overdone and causes more issues than it solves. This includes many "name" experts.
Flap "tweak": primarily affects the ROLL axis. Bend the flap horn for a ground-fixed "aileron effect" to make roll angle identical with positive and negative accelerations (Gs).
Leadout adjustment: primarily affects the YAW axis, but cannot be separated from rudder adjustment. I use the leadouts to take out *transient* effects, so that the leadouts and the equilibrium yaw angle are *complementary*.
Too far aft, and you a lot of line tension in level flight, but lose it overhead. Too far forward, and the airplane noses in at every control input and loses line tension.
The leadout position is related to the center-of-gravity. For my purposes, the "baseline" leadout position can be calculated using the computer program "LINEII" downloadable from Pete Soule's website. The position calculated this way is the position that corresponds to the "0 yaw angle" ideal.
Others use the leadout position to create "opposing forces" so that they have a rather large equilibrium yaw angle, and then overcome the ill effects overhead by forcing the nose back in with a forward leadout position. This creates yaw, roll, and (because the line tension changes when yawing and rolling) pitch transients.
Differential flap area: This "adjustment" primarily affects the roll axis. It exists to compensate for an interesting observed effect - that sometimes it looks like you need less tip weight to do a square corner than a round corner, and less tip weight to do a round corner than to fly level (all assuming 0 roll angle). Folklore says this is so you can "carry more tip weight", which is vaguely correct if you only see things in "binary". It's really because of aerodynamic asymmetry effect (even if you have equal-span wings) of flying in a circle.
Wing asymmetry: this "adjustment" primarily affects the roll axis. It was originally envisioned as "using the fuselage/engine as tipweight", which, once again, is vaguely, notionally, correct. In fact you are attempting to line up the lateral CG position with the lateral center of pressure. 1/2-3/4" is about right, more leads to less tipweight, but more likelihood of needing a lot of differential flap area. That's because everybody just moved the wing off center - and left the tail right down the middle!
Wing fences/drag tabs/drag vanes - other ways of doing various things. Never seemed to prove useful over the long haul, sometimes useful for specific problems, I don’t think it’s worth going into at this point.
Pitch Adjustments
Nose weight/CG: used to adjust the CG of the airplane, which controls the stability, and secondarily, controls pitch rate/lift ratio. More nose weight makes airplane require more control movement and thus control force for a given pitch rate and is more "stable". More stable also means more tendency for corners to "open up" in the wind. The more aft the CG the less control motion it takes for a given pitch rate, and the less "stable" it is.
Handle spacing: used in conjunction with the CG adjustment to create the desired control response for the pilot. More spacing = more sensitive, less spacing = less sensitive
In general set the CG the way the airplane wants, usually as far aft as it can go and still have *slight* positive stability. The maximum allowable aft position depends on the tail volume coefficient. Then set the handle spacing for the control sensitivity you want.
Flap/Elevator movement ratio: used to set the pitch rate/lift ratio, which sets the quality of the turn. In some sense this depends on the wing loading - heavier and you want more flap motion than elevator, and lighter and you want less flap motion than elevator. This can be a rather subtle adjustment and for most people just setting it to 1:1 (or whatever the original designer wanted) is probably going to work for you.
Flap/Elevator neutral/incidence: Used to adjust the inside/outside turn rate, OR, maximize tracking/stability. Most airplanes of conventional layout need some down elevator at neutral flap to fly best. Partly this is because of aerodynamic asymmetry (thrust line/wing/tail out of line and/or other drag asymmetry) but mostly it seems to be due to the pitch component of gyroscopic precession (which creates a constant nose-up pitch torque, for which the "down elevator" is compensating).
Adjust to find the "sweet spot" in tracking. Usually, ANY "up" elevator at neutral flap is severely destabilizing, and a lot of down seems to be pretty well tolerated.
Positive stab incidence is just a (permanently built-in) version of the same thing. I would recommend doing this ONLY if you have discovered that a particular design always needs it. It's obviously hard to adjust so leave this to the experts (fools) like myself. If you build an Infinity it wants to be about 1/4 degree.
Downthrust - Used for roughly the same purpose as Flap/elevator neutral, compensating for the same asymmetrical pitch effects. More downthrust raises the thrust line, creating a nose-down pitch torque. Easier to adjust than positive incidence, assuming you don't mind messing up the spinner fit. Once again, build in only if you really know it's necessary or beneficial. I would guess it's less likely to screw anything up than positive incidence.
On the topic of these pitch asymmetries - Folklore indicates that "since the airplane has to fly the same upright and inverted everything has to be 0-0". Once again, folklore is vaguely correct, in that it needs to fly the same upright and inverted. But our airplanes are nowhere close to symmetrical in the pitch axis even if the wing and tail are aligned perfectly. So there's nothing magic about 0-0-0 (wing/tail/engine), in fact it's a gross oversimplification. That knowledge helps ONLY to break the closed-minded assumption that if you put it all at 0-0 and it doesn't fly perfectly, it must be "misaligned".
I think this more or less covers most trim adjustments.
Basic (simplistic) trim process
This is a very over-simplified sequence, but if you do it correctly it will get you very close to the optimum trim, assuming the airplane doesn’t have any serious misalignment of the stabilizer to the wing.
Set the CG: The desired starting CG position depends on the tail volume. It’s somewhat of a debatable strategy, but Ted Fancher has a rule, that despite it’s simplicity works out about right assuming you have a relatively conventional airplane. Compute the ratio of the tail area to the wing area (including flaps of course). That should come out to something like 0.18-0.26 (or 18 to 26%). Then set the CG at about that fraction of the mean chord. So, for example, you have a 25% tail, and an 11” mean chord. The CG should be about 2 3/4” from the leading edge at the point of the mean chord. This is the MAXIMUM aft position. If you are going to make a mistake, or can’t get it quite where it says, err on the side of further forward.
And, importantly, don’t leave it in the wrong place to save weight! If you need 3 oz. of nose weight, then so be it. You can’t save weight by compromising the trim. Or, actually, you can, but you’ll lose an awful lot of contests that way. Same with tip weight. Trim is more important than weight, period.  That’s so important I will repeat it - Trim is more important than weight!
Leadouts: Plug in all your numbers into LINEII and make sure you take out the “whip angle” that is in the default settings. Then put the leadouts where it says relative to the CG.  (labeled “Leadout Offset”). For a check, a typical 64 ounce 40 -60 airplane on .018 lines, it comes out about 3/4”. So put the centerline of the leadout guide 0.75 inches behind the balance point.
Unless the designers says otherwise, set the flap/elevator ratio to 1:1 and the flap/elevator neutral to 0-0 or a little bit (maybe 1/16) of down elevator at neutral flap, and no downthrust.
Fly it upright and inverted. If the outboard wing is high both ways, add tip weight until it's level. If the outboard wing is high one way and low the other, tweak the flaps to roll the airplane so it's the same upright and inverted. Watch in hard corners. If the airplane rolls away from you in hard corners, take out tip weight. If it doesn't, add tipweight a little at a time, until it does noticeably roll away from you, then take out the last bit you added. If it pulls hard in level flight but severely falls off overhead, or tends to go loose on the first leaf of the clover, move the leadouts forward a bit (1/16 at a time). If it suddenly "comes loose", usually on insides, move the leadouts back a bit until it stops doing that.
That should get you pretty close. If you have an abnormally light airplane watch for a tendency to "swoop" into corners (looks like it rotates around a point behind the airplane) increase the elevator motion relative to the flap A LITTLE BIT. If you have an abnormally heavy airplane you might need to increase the flap motion relative to the elevator.
Adjust the handle spacing to get an agreeable control response. Don't set it up for excessively quick response.
Once you get it close, start watching for the airplane to “leap” around corners, come out higher than you expect on round loops, or have the control effort suddenly become “light” in square corners.  If that happens, try moving the CG forward a little bit at a time until it stops, and then readjust the handle to get the right sensitivity.
If the airplane feels heavy on the controls and wants to come out lower than expected on round loops, move the CG aft a little at a time until it quits.
Another CG measure is what happens when the engine quits. If the airplane pitches “up” right when the engine quits or is very “floaty” in the glide, the CG is probably well too far aft. If the airplane pitches “down” as the engine quits, and is very easy to “”whip” in the glide, the CG is probably well too far forward.
That's a far as I think we can go in the hypothetical, but it will be *very close* if everything is straight and reasonable weight and power."
Offline Matt Colan
« Reply #5 on: August 02, 2009, 05:07:47 PM »
Steve, the ST 60 is swinging a 13-6 Bolly prop at 8600 RPM.  Today we didn't fly, but we decided to move the leadouts foward a little bit.  We hung the plane from the leadouts and the nose was down, so we moved them foward and now the plane is level.  We'll see what happens next time we fly, maybe tomorrow.
Alan, he's been working out to keep himself in shape to fly, and today I told him he should work out more so he can take the pull of the P-40.  Our next contest is in less than 3 weeks, and there is going to be a fun fly day on Saturday, so if we can't get it worked out, we'll work on it a Lee.
Offline Matt Colan
« Reply #6 on: August 03, 2009, 06:34:19 AM »
In case anybody's interested, this is the P-40 that grandpa keeps complaining about too much pull.
« Reply #7 on: August 03, 2009, 08:06:32 AM »
I think the lead-out position is the ticket.  The description of the problem fits (the ringer is loss of tension up high)
PLAN B: make Gramps bulk up - try feeding him extra helpings of mashed spuds & gravy!  >:D  mw~  LL~  LL~  LL~
Offline Matt Colan
« Reply #8 on: August 03, 2009, 08:27:52 AM »
No loss of tension up high, but we did move them, and we'll see what happens next time we fly.
