  • June 25, 2025, 07:39:45 AM
Author Topic: Jr. Nobler, a little help please!  (Read 3276 times)
Offline Terry Bolin
  • Havin' the time of our lives!
« on: February 13, 2007, 08:07:10 AM »
I recieved my Plans from "Stuka Stuntworks" yesterday and they look to be the actual plans from Top Flight kit so my question is: can someone check their plans or model and tell me the actual size of the tail feathers? Also, does your plans have each rib drawn?
Thank you!
Terry Bolin
Re: Jr. Nobler, a little help please!
« Reply #1 on: February 13, 2007, 10:49:03 AM »
HI Terry,
So far I have not seen a plan that shows all the parts. ???
Hopefully, someone will trace the parts and *maybe* Pat Johnson, Bob K., or another can do them in CAD.
It is a surprisingly good flying small plane.  I would think an OS 10FP would be SUPER in one.
Bill <><
Offline dennis lipsett
« Reply #2 on: February 13, 2007, 12:33:55 PM »
HI Terry,
Bill <><
Yes if only the front end wasn't butt ugly. Dennis
Offline George
  • Love people, Use things.
« Reply #3 on: February 13, 2007, 01:29:33 PM »
Terry,
You can use the isometric view to get the approximate dimensions of the stab and elevators.
Next you can use the side view to get the airfoil shape. Note that the airfoil is at the place where it goes through the fuselage. You need to interpolate to get a root and tip rib using the length from the wing top view. Use the "stack" method to make the ribs.
You will also need to create your formers using top and side view.
A bit of annoyance, but doable. Good luck.
George
George Bain
AMA 23454
Offline Jay
  • 1 Cross +3 Nails= 4 Given
My religion consists of a humble admiration of the illimitable superior spirit who reveals himself in the slight details we are able to perceive with our frail and feeble mind.
Albert Einstein
  278622
« Reply #5 on: February 13, 2007, 03:53:03 PM »
Hi Jay,
That's Gary Weaver (used to be, maybe still is??) from over at SSW.  The guy who does all the wild things! **)
Bill <><
Offline George
« Reply #6 on: February 16, 2007, 11:29:14 PM »
Bill,
A little further down on the ebay link it mentions that it is indeed Gary. He is one guy who REALLY likes to play. He does stuff that most of us wouldn't even think up. Haven't seen him post in quite a while.
From what I can make out from the pic, those seem to be well drawn plans. All of the parts are shown.
George
George Bain
AMA 23454
« Reply #7 on: February 17, 2007, 07:59:22 AM »
Bill,
George
Hi George,
I knew that Gary used "scientificsupply" as his ebay handle.  He's done some things that makes you wonder..................
;D
Bill <><
Offline Brian Thwaites
  • ACE
« Reply #8 on: February 19, 2007, 05:11:45 PM »
Hi Terry
the span of the stabilizer is 14" if you want i have photo copies of the ribs full size if you would like me to email them to you
Brian Thwaites
  • ACE
« Reply #9 on: February 20, 2007, 05:01:50 PM »
here are the copies
Brian Thwaites
Offline George
« Reply #10 on: February 21, 2007, 11:26:07 AM »
If you build (any plane) from plans, make sure you have some holes in each rib of the outboard wing to stabilize air pressure inside the wing.
George
George Bain
AMA 23454
