INTERESTING...Howard!
You have brought up some interesting ideas..
I wish Gary Letsinger would jump here.....His knowledge on aerodynamics is awesome.
Way back in the early 90's our new Boeing Icing tunnel was completed and our model shop had the difficult (almost impossible assignment to made up various test wing test airfoils sections that were needed to conduct not only how moisture (rain) but also slush' and ice effects the airflow and lift over wing and airplane body structures.
We almost felt like short order cooks at times as we mixed up various batches of the strangest slathering fomulas, goo, and gunk that then was coated onto various flying surfaces.
Many of the model makers spent months..and tested so many various conditions (both in the tunnel and out on the field on actual flying test bed airplanes) that flying objects n' aircraft are exposed during even one simple flight.
Engineering Filmed and recorded how ice builds up on not only flying surfaces...but also how these changes can effect even the Center of Gravity and pressure...etc. I was surprised on just how much seeingly little build ups can but an airplane at risk...so quickly and often so over looked by the pilots....until its TOO LATE.
However on our models...I think sooo much is over-looked starting at the flying lines themselves.
Especially solid flying lines. Amazing just how little moisture or dirt can cause those lines to "Stick-bind- from mearly moisture surface tension itself. Be it wet grass, oil drippings from a leaking automobile engine or tranny onto the tarmac..etc. Add a little trizzle or a downpour..the outcome of those lines 'grabbing are pretty certain that your control input to the bell crank will be noticably effected quite quickly. Again braided lines rule...90% of the time as far as flexibility and freedom from binding.
As far as rain traveling by the force of gravity, along the flying lines in flight..and then into the small lead-out holes, where the leadouts travel....although possible???
Yes, some moisture could enter the wing, but that model in flight does have so many possible points where moisture could also enter...etc. I think perhaps that the amount of rain that could change the airfoil or weight on the model itself..IN FLIGHT...might actually be quite minimal...but again?
At the speeds we travel......I think air pressure due to the air density could also have an effect..also the air temp. etc etc etc.
BOTTOM LINE! I TAIN'T NO GARY LETSINGER, PAUL WALKER, OR HOWARD RUSH! Howard your knowledge about flying objects....are good enough for me to take to my bank anytime, brotha'?
Flying a beautifully finished stunt model in a steady downpouring of rain...really kinda BUNCHES MY BRITCHES...and would kinda get my panties in a knot, when I even think about it. Hummm? Maybe even to the point where I would have to wear "ATTENDS"adult diapers....n' all that jazz?
I was blown away...how little data, R&D studies have been conducted since the Wright Brothers first flew about such things as airflow over wings, or loss of lift etc....or how rain, ice build up or other weather factors can induce many dangerous flying conditions that can so easily and quickly effect changes to the flight of airplanes.
Some airports in various parts of the world...are at extreme risk from weather and climate variations...such as thunderstorms that can dump huge amounts of moisture, rain, snow, sleet, etc. onto flying surfaces of wings but also onto runway surfaces and even worse...the effects that sheets of rain and water can have on an aircrafts flying airfoiled lifting surfaces...etc.
Good input GANG...KEEP IT COMIN?
