  • July 18, 2025, 10:02:41 AM
Author Topic: Tongue Mufflers  (Read 1002 times)
Offline rich gorrill
Tongue Mufflers
« on: March 26, 2019, 05:18:25 AM »
I have aluminum stock to make my own tongue mufflers, where do I find the preasure fittings for muffler preasure. Any help  would be appreciated.
TIA
Rich
Offline Perry Rose
Re: Tongue Mufflers
« Reply #1 on: March 26, 2019, 05:28:19 AM »
Du-Bro, hobby shops have them. Du-Bro also has 6" aluminum exhaust extension stock p/n 213. All you do is cut it to length and drill and tap the bolt holes and cap the end.
Re: Tongue Mufflers
« Reply #2 on: March 26, 2019, 09:26:55 PM »
this is the Du Bro one . Had one , which was usefull , as it ' Bolted In ' a muffler .  But NOTE ,
the Threads NOT right down . Tho it has a nut , so ye dinnae need to TAP the Fred .  However FOR a tapped thread , Youd need a Thick Washer .
Some Stores have stocks of say OS or ST Pressure Take Off fittings to replace backplate bolts . Typically 3 m.m. thread . Needs Hole Tapping .
Theres 10.000.000 differant  ones on google 'Du Bro  pressure Fitting ' . So use watevers handy .
BAR some like smallis holes , not the big OS ones in their muffler fittings . ?
https://www.google.com/search?q=du+bro+.+pressure+nipple&tbm=isch&source=univ&client=firefox-b-d&sa=X&ved=2ahUKEwiRmY_drqHhAhVLWysKHXL6Ba8QsAR6BAgJEAE&biw=1280&bih=883#imgrc=C2XjxaoE0SeSgM:
