  • June 25, 2025, 08:53:59 PM
Author Topic: Ball link's...  (Read 1846 times)
Offline Bootlegger
Ball link's...
« on: October 29, 2009, 09:14:33 AM »
   The DuBro part # that I see is 884 is this the correct one install in the B/Crank to have a flexible type push rod going to the flaps? If not what # do you use and why?
    Again thanks...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Jim Oliver
Re: Ball link's...
« Reply #1 on: October 29, 2009, 10:09:32 AM »
Flexible type push rod???  'Splain that one for me. n~
Jim
Jim Oliver
AMA 18475
Offline Bootlegger
Re: Ball link's...
« Reply #2 on: October 29, 2009, 10:37:51 AM »
 Jim, It isn't flexible as in limber, but with the ball joint the movement isn't  as limited as with the wire going into the push rod hole in the b/crank which sometime's causes binds..
  I've seen these setups but don't have all the info that I need.
  Hope that this answer's your question..
Gil Causey
AMA# 6964
Offline Jim Oliver
Re: Ball link's...
« Reply #3 on: October 29, 2009, 11:04:23 AM »
Gil,
I don't have the Dubro part # handy; I have been using the ball links that screw onto a 4-40 thread and have a
2-56 screw through the ball and into the control horn.  I believe these are OK for 35-46 size models. I use the small Rocket City links on larger stuff.
Both sizes of the Rocket City links are available from Tom Morris and probably Jim Snelson.
Jim
Jim Oliver
AMA 18475
Offline Geoff Goodworth
Re: Ball link's...
« Reply #4 on: October 30, 2009, 12:09:35 AM »
I am not at all sure about the Dubro 884.
I have some 497s and heavy duty 899s. The 899s are the same size as the Rocket City links that I bought from Tom Morris several years ago. Whether they are the same mechanically, I don't know. Certainly, the little brass stand-off that Dubro supplies looks like it could be useful with long flap horns.
Re: Ball link's...
« Reply #5 on: October 30, 2009, 12:16:39 AM »
I always find that I need a *stand off* when I use a ball link at the bell crank.  The conical brass ones are perfect, and I have had to add a few washers or a nut below them (between the brass cone and BC) a time or two..
Mongo
Re: Ball link's...
« Reply #6 on: October 31, 2009, 07:27:57 AM »
Another little point I have discovered this week,  the threaded part/hole does not go all the way thru on all of them.  I measured the 4-40 ball links I have and the threaded portion is only 1/2 inch deep.   So i measured the 4-40 rod so only 3/8 of an inch is screwed in.  I am wondering if the is what happened to an individual some time back that lost his plane because of a broken 4-40 ball link.  The only time I use the 2-56 ball links is for small planes and the throttle arm on throttle contro engines.  Have fun,  DOC Holliday
