General control line discussion => Open Forum => Topic started by: steve pagano on September 13, 2007, 11:58:31 AM
Has any one ever used this stuff for paint masks/stencils? I have a lot of it lying around and since it's easy to cut i figured why not? lol
T.I.A
-Steve
Yes Steve
I have used it a lot over the last 2 years or so
lay a piece over your plan, for example, wing rib
I use a sharp scribe to make the outline, enough to
score the surface, then cut oversize with scissors,
then crack along the score lines , carefully and a
very light sanding finishes the template
Best of luck with it
Vincent
I would not think it would work for painting masks if I read the post correctly. It is used for making emplates of parts. Have fun, DOC Holliday
SeeTemp is a great product, but as a paint stencil, I don't know. Wouldn't it produce an awfully thickpaint edge??
I love the stuff!
I feel it's the best method for making templates off full size plans.
How thick is see temp ?
