  • June 27, 2025, 08:01:09 PM
Author Topic: What do you all do in this instance  (Read 1348 times)
« on: July 07, 2009, 09:18:35 PM »
I have asked this before  - but nobody really answered.
Pretty much every plan I have (and that is over 700) shows the same details on fixing the stationary flap to the TE - and in all cases the TE is wider than the tab or fixed flap - so in the location of the fixed tab at the end of a wing – how do you get a smooth transition for the TE to the tab???
If you follow the shape of the airfoil, you drastically reduce the area of the tab.
Generally I have used filler here to make a smooth transition – but is there a better way?
What do you all do?
Re: What do you all do in this instance
« Reply #1 on: July 07, 2009, 09:52:09 PM »
Your last pic is how I would do it, Wynn. The flat flaps most of us use make this proper, it follows the airfoil of the rest of the wing. I make the outboard tab an adjustable surface.
Chris...
« Reply #2 on: July 08, 2009, 08:55:53 AM »
Ditto on what Chris said.  DOC Holliday
Offline Ward Van Duzer
« Reply #3 on: July 08, 2009, 01:23:37 PM »
Y'all gotit Toyotas!
W.
Offline Bryan Higgins
« Reply #4 on: July 08, 2009, 10:39:11 PM »
Design the rib TE higher then use an applicable flap design to fit for a smooth transition.
It will take some work , but what does not.
My two cents worth. D>K
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
