  • June 26, 2025, 01:06:50 PM
Author Topic: My favorite New Flying Machine  (Read 2877 times)
Offline Chuck_Smith
« on: January 22, 2021, 04:48:14 AM »
This is what happens when you let your engineers loose to dream.
https://americanmagic.americascup.com/
AMA 76478
Offline Gerald Arana
Re: My favorite New Flying Machine
« Reply #1 on: January 22, 2021, 07:48:00 AM »
WOW! That's cool. They sure get a lot of lift from those.... eh.....wings(?)
I wonder what water foil (?, can't say air) they use. I'd like to see that sailboat zip across the Pacific.  ;D
Jerry
Offline Steve Dwyer
« Reply #2 on: January 30, 2021, 08:39:55 AM »
So totally cool!!! When I sailed (Raced) as part of Fleet 204 Oneida Lake, NY all over the NE using my Hobie 18 Magnum in my 30's I never thought a monohull would ever outclass a catamaran. The days of telltales are long gone here.
Offline Dwayne Donnelly
« Reply #3 on: January 30, 2021, 08:57:54 AM »
Absolutely awesome technology, but to be honest I miss the yachts.
« Reply #4 on: January 31, 2021, 03:11:28 AM »
Back in 1982, a friend that attended Cal Poly Pomona with me in mechanical engineering selected as his senior project the design and fabrication of a set of foils for his Hobie cat. He cut the upper surface to a pure arc since that he felt it would be adequate, but also because it seemed easiest at the time. He used a very large barrel fixture and mounted the foil blanks on it and turned the whole ensemble on a huge lathe. As I recall, in the test phase he was able to get it foil-born, but anything that disturbed the boat in pitch required a lot of luck to stay up. He used some type of float on a lever arm to automatically adjust the foil pitch.
Seems like forty years and cubic dollars has advanced the concept a bit....
« Reply #5 on: January 31, 2021, 03:10:22 PM »
It's not really beautiful, but looks highly functional.  It appears they will have (maybe already).  Thought I saw that they would be racing.
« Reply #6 on: January 31, 2021, 03:12:31 PM »
Me too!  They are much "prettier".  The pros probably don't like that they can be very evenly matched.
Offline Reptoid
« Reply #7 on: January 31, 2021, 03:20:53 PM »
Well; technically it's not a "monohull" at all. It's a "Hydrofoil"
       Don
       AMA # 3882
Offline Skip Chernoff
« Reply #9 on: January 31, 2021, 06:36:37 PM »
I've never seen that. It's crazy!
« Reply #10 on: March 12, 2021, 10:30:18 PM »
  I have always had an interest in the Americas Cup event, but haven't paid much attention to it in a lot of years. My how things have changed!! Anyone know where I can read about the current current trend ion design and how they function?  I notice also after watching the 6th race in the finals tonight that they don't don't run a triangle course any more, apparently to not have to make a down wind run. I always liked to watch the sail and course changes!! Talk about team work!!
Offline Chuck_Smith
« Reply #11 on: March 13, 2021, 04:25:49 AM »
I do miss watching them set the spinnaker. That was the sailing analog of a pit stop in motor racing.
AMA 76478
Offline Steve Dwyer
« Reply #12 on: March 13, 2021, 11:49:32 AM »
Isn't it a monohull craft with a hydrofoil plane in the wate?
