  • June 18, 2025, 07:22:34 PM
Author Topic: Pathfinder MK 1 and 2  (Read 1228 times)
Offline Ross Smith
« on: November 09, 2020, 02:56:47 AM »
Hello. Could anyone please outline the main differences between the Pathfinder Profile ARF , and the brodak  kit which is labelled Pathfinder MK 2?
Thanks in advance .
Roscoe :)
Offline Perry Rose
Re: Pathfinder MK 1 and 2
« Reply #1 on: November 09, 2020, 07:59:29 AM »
Your best bet is to call Brodak. If you have the choice buy the kit. Maybe the MK 11 stands for Appearance points.
Offline John Miller
« Reply #2 on: November 09, 2020, 10:10:11 AM »
The MK1 is the first version published as PathFinder PRO-file, in Flying Models. Kenn Smith, now deceased, released a run of 200 kits of the MK1 from his company, Smith Models around 1995. The MK1 had a longer wingspan than the MKll and used a wide, notched, single spar that allowed a twist and lock method for installing the ribs. It did not have a sheeted leading edge but instead, used half ribs.
Due to the feeling that the spar may be a possible liability Gordan had me make a few changes to the plans that are used on the Brodak MKll version. Basically, he shortened the wing, and went to a C tube, leading-edge. This made the wing stronger, and less liable to flexing.
If you go to the vendors' corner, here on Stunt Hangar, and look under CadClassics, there's a pretty complete history about the Pathfinder series that may be of interest.
I'm attaching a picture of an MKll  converted to an electric Pathfinder Twin, built by modifying an ARF
John Miller
Offline Ross Smith
« Reply #3 on: November 16, 2020, 01:19:35 AM »
Thanks for the comprehensive information I received from the replies. I have all the information I require. I have an ARF which is my practice plane, as well as a new kit.
Cheers Roscoe.  take offs are optional , landings are compulsory.
